Latest news: ---- hi all ---- Node Ediabas Voltage Control Tool ---- DIAGBOX v9.260 FILES FULL MEGA ---- Piwis online ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 FULL ---- TOYOTA DENSO ECU IMMO DTC FILES MEGA ---- Xentry SDconnect Toolkit Fix 09.2026 ---- XENTRY RELEASE 4 - 09.2026 FILES ---- SRS AIRBAG CRASH KILLER + KEYGEN FULL ---- Kraken Auto Database ECU Tool ---- Autotuner File Converter Tool ---- SDT-II 2.43.0.126 Files MEGA ---- MUT-III PassThru 26061-00 Files MEGA ---- BMW ISTA GUI 2.1.0 NEW UPDATE ---- Scania DEC2 Engines Control System Software Files ---- BMW ISTA 4.57.21 Polish Language ---- BMW PSdZData 4.61.30 Files FULL ---- FVDI Software Download Files MEGA ---- FTAG 1.1.0 Checksum Correction Tool MEGA ---- All BMW Maps In One Place Files Torrent ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ----
VAG ETKA 8.1 (1511) + 8.2 (1587) 01.2025) + 8.3 - Torrent (without pass)
VW
VAG ETKA 8.1 (1511)  + 8.2 (1587) 01.2025 + 8.3 - Torrent (without pass)
The ETKA electronic catalog contains complete information on spare parts and accessories for VAG vehicles (VW, Seat, Skoda, AUDI), including minibusses.
Works on Windows x32 and x64.
Patch and instruction inside.
Added new version VAG ETKA 8.1 (1432) 01.2022
Added VAG ETKA 8.2 (1474)
Thanks given by: WoodrowVam
trb.ro Offline
(11-25-2022, 06:38 PM)aleksey-ms Wrote: Added VAG ETKA 8.2 (1474)
Hello Aleksey,
 I have a hiccup with the installation. After everything is installed correctly by using the instructions .txt,  when i run Ekta, i get myself this message:
information über den vorhandenen Hardlock
Version der DLL 2.12
Beim Ansprechen des Hardlocks trat der Fehler 7 auf
Translation by the holy google:
information about the existing hardlock
version of the DLL 2.12
Error 7 occurred when addressing the hardlock
Tried the following steps to address the issue:
- performed an uninstallation of Ekta, with registry cleanup to ensure a clean entry of the reg files. (HKEY_CLASSES_ROOT, HKEY_CURRENT_USER, HKEY_LOCAL_MACHINE entries were deleted accordingly, and checking USERS & CURRENT_CONFIG revealed no extra reg entries)
- doublechecked for any residual files/folders
- reinstalled with the same error afterwards.
Tested on Win7 x64 hardcase laptop used primarily for auto diagnose for VAG cars (VCDS however is not yet present as it is a fresh OS install and i wanted to start off with EKTA before VCDS).
Please advise if you happen to know a way around this. I am sorely tempted to nuke and reinstall the OS but i'd love to avoid that Big Grin
Cheers from Bucharest!
Hello Aleksey,
Hello. There may be too many reasons for this error. If you need help installing, send me a PM.
Added VAG ETKA 8.1 (1485) + 8.2 (1487)
Added VAG ETKA 8.1 (1511)
VAG ETKA 8.2 (1587) 01.2025
D7I.c Offline
What's the password for version 8.3? Because it asks me to enter a password as soon as I install it.
