Latest news: ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ----
BMWAiCoder 5.0 - for coding BMW on Windows
BMW
BMWAiCoder is a program that makes coding a car much easier due to its simplicity. The interface has been translated from Chinese into English, so using the program will become much more comfortable if you do not speak Chinese, of course.
Each button is numbered, allowing you to encode in numbered steps. However, the program is limited in functionality compared to E-Sys, and it is not stable as it is constantly being updated. The program is designed to quickly encode certain values, so do not use it for full-scale encoding. The most stable version of the existing is 4.6.
What version inside:
  • 5.0
  • 4.6
  • 4.4
  • 3.7
[*][Image: BMWAiCoder.jpg]
Added Mega link.
Thanks given by: leszek11 , leszek11 , aminBen , aminBen
The link is working again
aminBen Offline
(11-14-2020, 08:49 PM)aleksey-ms Wrote: BMWAiCoder 5.0 - for coding BMW on Windows
  • 5.0
  • 4.6
  • 4.4
  • 3.7
Hello Aleksey,
How you do in ?
Need the pass for bmwai coder, i have the chineese vers but understanding anything.
Need it for coding ambient light retrofit, if any one have tutorial for this.
I appreciate your help.
Thank you very much
