Latest news: ---- Tachosoft 23.1 + Activator Full ---- TIS 2000 + Dongle FULL ---- BMW ISTA+ 4.60.40 Standalone FULL ---- BMW ISTA 4.60.4x AND I-LEVEL OVERVIEW FULL ---- Navkal Pro ECM Programming With Activator ---- CNH Approval Password Generator + Keygen + Keymaker ---- John Deere Payload Encrpt Decrypt + Keygen + Full ---- BMW CAS 1,2,3,3+,4 FG FA TOOL FULL ---- RENAULT DDT2000 FILES COLLECTION MEGA ---- KIA HYUNDAI DTC EDITOR + KEYGEN ---- KIA Variant Codes Files Pack ---- BMW PSdZData 4.60.42 Files FULL ---- MAN KEY CATS TOOL ---- HYUNDAI KIA GDS SOFTWARE FULL ---- John Deere Service Advisor 5.3 2025 ---- HPT To BIN Converter + Keygen ---- MERCEDES SKCV CALC TOOL ---- Toyota Corolla Apple CarPlay Android Auto New Update ---- Help with Jpro installation ---- Pre-installed ODIS 25.0.3 and ODIS Engineering 19 ---- Man Repair Manuals Wiring Schematics Mega ---- PCMflash Original Version Drivers J2534 Wiring FULL ---- ECU Pinouts Collection IMMO Wiring ECU Pictures ---- JCB ServiceMaster 25.1.0 Unlocked + Fix MEGA ---- Best K-Suite Kess K-tag Version Update ---- WinOLS 4.7 Latest Version Update ---- KESS K-SUITE 2.48 Latest Version Update ---- Hello From USA ---- ETKA 8.6 International English 01.06.2025 Virtualbox ---- Vediamo 5.1.1 + Activator Tactrix OpenPort 2.0 Full ----
vocom II mini not detected by techtool
translucian Offline
I bought a new original vocom 2 mini with wifi only.
I tried to pair it successfully with vocom II monitor and it worked,
I use only acces point mode and set mapping in different modes for it to be availible.
The issue is the unit does not pass communication to vehicle j...protocol and techtool sais that there is no vocom II tough connected.
Has anybody figured this out ?
Thanks given by: Smer4dsn , Rayzen , bungee83 , DANI1980
ied99 Offline
(11-11-2021, 06:51 PM)translucian Wrote: Hello,
DID YOU FIX TAHT I HAVE THE SAME PROBELM PLASE!
ADS69 Offline
Hi,
Your problem is most likely not with the Vocom itself, but rather with the configuration or compatibility.
Here are the most probable causes:
PTT version too old → the Vocom II Mini is only recognized from version 2.8 onwards. If you're on 2.7 or earlier, it will never be detected.
Wi-Fi mode → in access point mode, the software doesn't recognize it properly. Put it in Client mode (so it connects to the same Wi-Fi network as your PC).
Drivers → check in Device Manager that you have "Vocom II Mini Ethernet Adapter". If not, reinstall the drivers via the Config Tool.
Vehicle protocol → the Mini doesn't always support J1708 (only CAN/J1939). If your truck is a bit older, that might be the issue.
Try this first, but in my opinion it's either the PTT version or the Wi-Fi mode.
Thanks given by: MizteriouzA , motya , ZAGO , byarifo , lordhaos00 , Frankywaf
