Latest news: ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ---- BMW ISTA Czech Database 4.57.XX 4.61.XX MEGA ---- BMW ISTA+ 4.61.1x Files MEGA ---- BMW ISPI ISTA LAUNCHER 1.61.02.2059 MEGA ---- DASH CALCULATOR TOOL FULL ---- Fiat MultiEcuscan 5.3 - 2024 ---- ISUZU SERVICE REPAIR MANUAL PACKAGE ---- Odis-S 25.3.0 + Odis-E 21.0.1 Full 08.2026 ---- XENTRY 09.2026 RELEASE 4 FILES ---- Can Clip 221 Tactrix OpenPort PassThru + Keygen Full ---- CAS-2 Editor 3.1 Tool FULL ---- PORSCHE ENGINE 2.9 BITURBO WIRING DIAGRAM ---- MB 7G.SCN Coding Data Collection Offline Programming ---- PCM Flash Dongle Drivers J2534 FULL ---- All Cars Pin Diagram Tool Full ---- Hello, let me introduce myself. ---- Hello ---- Inpa64 Tool64 Update Ediabas 7.7.2 Full ---- VCDS To HEX-V2 VIIPlus Loader STM FULL ---- BMW Navigation Map Europe Live 2026-3 ---- DTS Monaco 9.02 Keygen + Patcher FULL INSTALLATION ---- MAZDA 5 ELECTRICAL WIRING SCHEMATIC ---- Wabco Toolbox 13.7 + Pin Calculator New Update ---- Honda China 2022-01 VmWare Virtual Machine ---- VCDS 26.3 FLY V2PP + LOADER FULL ---- Vag Commander v5.5 ----
hello I need help
raulinonog Offline
Hello, can anyone help me, I'm trying to install scania multi 23.05 and I'm getting this error on disk 2 auth.
Thanks given by: Mbstar , saexy
Khalid0520 Offline
(05-09-2024, 07:06 PM)raulinonog Wrote: Hello, can anyone help me, I'm trying to install scania multi 23.05 and I'm getting this error on disk 2 auth.
0. You may have to remove the previous version of Multi (along with the database).
1. Install Net 3.5
Start - Settings - Applications - Related settings (Programs and Features) - Enable or disable Windows components -> Net Framework 3.5.
Without this, the database will not install.
2. Mount or unzip ISO files. Install in order of priority (01, 02, 03, 04).
3. Run multi_2305_patch.bat with Administrator rights to reset the trial.
!!! If you see the error "Cannot open database Multi_DVD_**** requested by the login. The Login failed.." !!!
You need to change the path to the SQL server.
Launch Multi config from the Start menu.
View the path to the base.
It looks something like this: Multi_DVD_2305_1@MYCOMP\MULTI_SQL.
Edit the patch file - replace the path to the database with yours:
echo sp_password NULL, 1234, sa | OSQL.EXE -S localhost\MULTI_SQL -E
echo use Multi_DVD_2305_1; update multi_proparameter set text="*').$,#(" where item='PROD_STAMP' | SQLCMD.EXE -U sa -P 1234 -S localhost\MULTI_SQL -d Multi_DVD_2305_1
English:
0. Probably: uninstall previous Multi (including db).
1. Install Net 3.5 (need for DB installation)
2. Mount ISO files, then install in order 01, 02, 03, 04.
3. Run as Administrator multi_2305_patch.bat to reset the trial.
!!! If you got a message "Cannot open database Multi_DVD_**** requested by the login. The Login failed.." !!!
You need to replace path to SQL server.
Run Multi config from Windows Start menu.
Check "Folders for Multi data" - "Sql server".
It looks like Multi_DVD_2305_1@MYCOMP\MULTI_SQL.
Open the patch file to edit and replace existing names/pathes to yours:
Thanks given by: Galin90 , SFTY , max9183 , md89nl
kaspare Offline
Hi, you'd better start from scratch with the installation but first you have to clean up all the files of the old multi, uninstall the program from the control panel and then you have to delete this too (MultiCdView) in the programData folder and also delete the various MICROSOFTSQL files from the control panel SERVER of old installations
Thanks given by: forford , mamurozbot , AMSTER , Spawnrn
