Latest news: ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ---- ODIS 26 + Patch ---- Unlock ECU Seed key Calculator TOOL ---- ZOOMLION ZCC550V MANUAL NEED HELP ---- XENTRY XDOS XPT 09.2026 FILES MEGA ---- Allison DOC 2026 Official Commercial Diagnostic Software ---- Xdos SDconnect C4 To ConfigAssist Fix ---- HHTWin Win64 v1.9 Files FULL ---- Thermo King CanDiag 1.21 Software Full ---- Scania SDP3 v2.71.3.2 File Mega ---- WABCO SOFTWARE COLLECTION FILES FULL ---- Toyota GTSplus v2026.02.002 EU Files Mega ---- TMS374 DECODER IMMO OFF TOOL ---- BMW Easy Connect v1.3 New TOOL ---- iDecoder 4.5 VIN PIN DPF DTC TVA IMMO OFF FULL ---- Peugeot PSA Wiring Diagrams Files Full ---- PSA Interface Checker New TOOL ---- SUZUKI SDT-II 2.39.0.15 FILES MEGA ---- BMW ETK Price 09.2026 ---- Wabco Software Collection Full ---- Scania Xcom 2.54 + Plugin Full ---- John Deere Payload Files Complete Mega ---- MUT III SEPE FILES MEGA ----
citroen c1 auto box config
stevec1 Offline
Citroen
i am trying to do a a re-learn on a citroen c1 semi auto gearbox, apart from using the diagbox software, can anyone recommend another program to do the re-learning after the clutch replacement, delphi does not give me the option and i dont currently have the hardware box for the psa diagbox software.
Thanks given by: Galenot , RidgecokS , fabry7768 , Shaikh , Nidzoba , hoschi001
dyann10123 Offline
Hello this method work without diagnostic system, all manually, but sorry i have only the document in french:
- mettre en position 'N'
- couper le contact
- il faut shunter les contact TC (13) et CG (4) de la prise obd
diagnostic
- attendre 10 secondes minimum
- mettre le contact
- enfoncer la pédale de frein au moins 7 fois en 3 secondes
- un signal sonore retentit 2 fois espacés de 0.25s
- avec le levier de vitesse : composez les séquences suivantes avec le pied maintenu enfoncé sur le frein.
initialisation de l'ECU :
N E M - M - M - M - E N
initialisation de l'embrayage :
N E M + M - M + M - E N
initialisation de la boîte de vitesse :
N E M - M - M + M + E N
- relâcher le frein
- enfoncer le frein une fois
- le signal sonore retentit ( intervalle de 2.5s entre chaque
réglage ou initialisation).
initialisation de l'ECU : deux bip espacés de 0.5s
initialisation de l'embrayage : trois bis espacés de 0.5s
initialisation de la boîte de vitesse : quatre bips espacés de 0.5s
Si vous n'entendez pas les bips : recommencez 15s au moins après avoir coupé le contact.
- pour finir : enfoncer la pédale de frein 3 fois dans un lap de 2s
- deux bips espacés de 0.25s retentissent
- couper le contact et attendre 10s
- débrancher le shunt
Thanks given by: Rafai999 , daryn41
