Latest news: ---- BMW Easy Connect v1.1 New Update ---- ZF Transmission Repair Manual Package ---- help please DAF v95 full installation and Turkish language support ---- BMW ISTA Launcher Console 1.2.4.14 TOOL ---- BMW Psdzdata Torrents Files Collection ---- iDecoder 4.5 No Registration Full ---- BMW ISTA Standalone 4.61.12 Files FULL ---- Renault CAN Clip 222 Scanmatik J2534 Full ---- ODIS Service 26.0 + ODIS Engineering 22 Torrent Files FULL ---- BMW ISTA GUI 2.0.1 NEW UPDATE ---- BMW Standard Tools 2.12.7 Software FULL ---- VAG IMMO TOOL NEW UPDATE ---- Hyundai Heavy Equipment Factory Service Manuals ---- DAF XDC II 5.61 v95.00 + DEVKIT TOOL FULL ---- Truck Explorer Software Files Mega ---- scania sdp3 ---- Caterpillar Factory Password Keygen Full ---- Pump Diagnostics BOSСH VP44 VP30 Files ---- MITSUBISHI SEPE + MUT3-SE 2024.12 FULL ---- Mazda IDS v140 File MEGA ---- WABCO TEBS-E 7.00 LANG ENG FILES ---- JPRO CURRENT VERSION 2026 v1.2 FILES ---- FRM BMW DFLASH DATABASE FILES ---- BMW E-sys 3.8.1 + Patch And Keygen ---- Davinci Deluxe Edition 2025 v1.0.37 Full Token ---- XPROG 5.5.5 NO DONGLE NEED FULL ---- SCANIA SDP3 V2.70.1.3 FULL TRUCKS + MARINE + KEYGEN ---- BMW ISTA Updater GUI 2.0.0 TOOL ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ----
HP Tuners BE CAREFUL
uglyoldfat Offline
If you have a MPVI 2 or 3 and have been using the cracked version of the software the last firmware update allows HP Tuners to see if you have been writing without a license and the moment you resync your interface it will be disabled.
When you start a ticket for help they will request you send the unit in and once they have it they will inform you that you have violated the EULA and will keep the interface and basically you are fucked.
I know 2 people this has happened to personally and all the screaming, shouting and swearing is not getting your interface back or any valid licenses either.
If you want to take legal action they will take legal action as well and prove you violated the EULA so good luck with that.
So keep your interface offline and don't update your software or your firmware as going back in firmware will not fix the issue either.
If you think I am full of shit then good luck is all I can say.
Thanks given by: alex_093 , alex_093 , alex_093 , alex_093 , muzikismre , unichip , Admin , Admin , lfas
alex_093 Offline
(02-08-2024, 10:50 PM)uglyoldfat Wrote: If you have a MPVI 2 or 3 and have been using the cracked version of the software the last firmware update allows HP Tuners to see if you have been writing without a license and the moment you resync your interface it will be disabled.
I confirm! vcm editor versions starting from version 5 began to track the number of records and their licenses. If you do resync, then it is more likely that your mpvi2/3 interface will be disabled.
Thanks given by: uglyoldfat , unichip
Lennydmax Offline
Does anyone know a way to fix an interface after it's disabled?
Thanks given by: MECANO35
phaleg Offline
only mpvi2 can fix
Thanks given by: uglyoldfat , uglyoldfat
uglyoldfat Offline
(03-04-2024, 07:14 AM)phaleg Wrote: only mpvi2 can fix
Any details on how to fix?
alex_093 Offline
How?
uglyoldfat Offline
How?
There is a thread on another forum do a search for "i resurrected my hp tuners mpvi2 device from the depths of hell" in google and it will come up.
Reading between the lines as he has not said how he did it but noted in a image he posted that he is using v4.10.4 and his firmware is an older version I think maybe he has gone back in the firmware version to as early as he can on v4 and possibly got it working. Since the MPVI3 does not work on v4 this would make sense why HP Tuner are trying to get everyone to upgrade.
Going back in firmware is easy enough there is a youtube video explaining it. https://www.youtube.com/watch?v=weZ6gfci6go
Further information has come out in that the MPVI2 has a sdcard inside it and that is what needs modifying and the MPVi3 does not have one so at this stage can't be done.
As to what he does with the sdcard I have no idea.
 I resurrected My HP Tuners MPVI2 Device from the Depths of Hell I resurrected My HP Tuners MPVI2 Device from the Depths of Hell
Thanks given by: yangchaoqun , yangchaoqun
Bullitt Offline
The interfaces are dirt cheap. If it happens your still in the black
uglyoldfat Offline
(03-18-2024, 11:10 PM)Bullitt Wrote: The interfaces are dirt cheap. If it happens your still in the black
True but some of us are dirt cheap as well.
NinJa_ Offline
thank you for the info @uglyoldfat I really appreciate it I will be trying to do a flash on my Silverado soon for the 4l80e swap
