Latest news: ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ----
BMW 2026 ISTA ISPI NEXT, ISTA, ETK, INPA, E-Sys, Ediabas, KSD, Testo and WDS
Carsoftcar Online
BMW
BMW ISTA ISPI NEXT, ISTA-D or P, ETK, INPA, E-Sys Launcher Pro, Dr.Gini Ediabas, KSD,Testo and WDS - Remote Install
BMW ISTA-D 4.57.30+E -Sys 4.54.20+PSdZDaten - $500 = $400
BMW ISTA ISPI NEXT Licence Generator (You can use it to create licences for offline ISPI ISTA) - $350
BMW ISTA ISPI NEXT 4.49.40 (1 Tb) - $150
BMW ISTA+(D) Rheingold 4.57.30 - $75
BMW ISTA-P Rheingold 3.72.300 (2024) - $60
BMW INPA 5.0, Coding Tool 2.5, NCS Expert tool 4.0, EDIABAS 7.3, VIN KFP Tool 5.3, SP-Daten 67 - $65
BMW PSdZDaten v4.5 - $55
BMW ETK 01.2020 - $55
BMW E-Sys 3.30.1 Launcher Pro 2.8.2 - $75
BMW E-Sys Plus 4.54.20 Launcher Pro 1 yers - $350
BMW Dr.Gini Ediabas - $55
BMW KSD - $55
BMW Testo - $55
BMW WDS - $55
 [Image: c96b8636deee7913fa7a55201d2d2b6a.jpg]
 BMW ISTA ISPI NEXT
Functions that will be available after installing the BMW ISTA D: automatic troubleshooting, reading / resetting errors, resetting service reminders, ECU adaptations, setting basic parameters, viewing measurement blocks, coding control units, information about control units, performer tests, programming units, other functions.
    List of programs included: BMW ISTA D, BMW ISTA-P, BMW Inpa, NCSEXPERT, WinKFP, Ediabus Conf, BMW ETK, NCS Dummy, BMW Coding Tool, Dr.Gini, ESYS Plus (additional option).
System requirements for BMW Ista:
• Laptop with at least i5/i7 processor
• RAM of at least 8 GB, but 16 GB and above is highly desirable.
• Availability of an SSD disk with a capacity of at least 1 TB, for Esis you need 2 TB
• Support Windows 10/11 x64 PRO
Some features of the ISTA system:
• It may not work completely with cars before 2014, it may not decipher fault codes or delete them, etc. This is due to the fact that the manufacturer removes support for old cars in new software versions. Therefore, for such cars we can install an older version.
• The system license is tied to the hardware and is protected from cloning. If deployed and run on another laptop, the license of the first one will be blocked. License restoration is equal to the cost of installation as for the first time.
BMW ISTA-D  is a dealer software designed to diagnose cars of.
BMW ISTA-P is a complex for programming and updating car blocks.
BMW ETK - a new version of the program for selecting parts
BMW INPA is a professional program for diagnostics, coding and programming of BMW, Mini, Rolls Royce cars.
BMW E-Sys is a very important coding program. The total number of parameters with which you can change the car exceeds 100 (each body has its own encodings).
BMW Dr. Gini for Ediabas. This software supports the following features:
·       Vehicle identification
·       Reading and deleting errors from the memory of control units
·       Reading and deleting adaptive data in blocks
·       Reading parameters and presenting them in convenient scales or graphs
·       Activation of actuators
·       Reading FA/VO codes
·       CIC / NBT map update
·       Expert Mode
To run, you must first install Ediabas on your computer.
BMW KSD contains a dealer catalog of standard BMW watches (BMW) and expert opinions, all BMW series are presented.
In the BMW KSD electronic database, information has been presented since the 60s (series 114).
In addition to the standard hours, the program contains catalogs of repair service packages, wheel and tire combinations, winter and summer tires recommended for use.
Carsoftcar Online
BMW
BMW E-Sys Plus 3.8.1 Launcher Pro - $99
Carsoftcar Online
BMW
BMW ISTA+(D) Rheingold 4.43.31 - $75
Carsoftcar Online
BMW
BMW ISTA-D+P+E-Sys+PSdZ+INPA+Coding+NCS+EDIABAS+VIN KFP Tool+SP-Daten - $265 = $225
BMW E-Sys Plus 3.8.1 Launcher Pro - $75
Carsoftcar Online
BMW
BMW ISTA+(D) Rheingold 4.45.21 - $75 (NEW version)
Carsoftcar Online
BMW
BMW ISTA+(D) Rheingold 4.45.20 - $75
Carsoftcar Online
BMW
Carsoftcar Online
BMW
BMW ISPI NEXT Licence Generator (You can use it to create licences for offline ISPI ISTA) - $350
BMW ISTA+(D) Rheingold 4.49.40 - $150
BMW ISTA+(D) Rheingold 4.49.40 (just an activation key) - $75
BMW ISTA+(D) Rheingold 4.49.30 - $75
Carsoftcar Online
BMW
BMW ISTA+(D) Rheingold 4.50.12 - $75
Carsoftcar Online
BMW
BMW INPA 5.0, Coding Tool 2.5, NCS Expert tool 4.0, EDIABAS 7.3, VIN KFP Tool 5.3, SP-Daten 67 - $60
BMW ISTA+(D) Rheingold 4.49.40 (1 Tb) - $150
BMW ISTA+(D) Rheingold 4.50.12 - $65
