Latest news: ---- HITACHI ALLINONE TOOL 3.9.0.0 MPDR 3.22 MEGA ---- VAG BMW MB OPEL PEUGEOT EDC17 FILES MEGA ---- Volvo Tech Tool Devtool License Editor Keygen Full ---- Fiat ecu map ---- SVEdit v1.1.38 ---- BMW E-SYS PSdZData Tool New Version Link MEGA ---- VEDIAMO PASSTHRU 5.1.1 + KG + PATCH ---- GM ECU FLASHER TOOL FIX ---- BMW CODING PACK FILES MEGA ---- iDecoder 4.5 No HWID Full ---- ECU Tuning Solutions 1.02 No HWID ---- VCDS HEX NET SUPPORT WIFI DOIP TOOL ---- BMW ETK Price 11.2026 ---- K-Suite Collection Professional Software Kess V2 K-TAG ---- GM GDS2 SOFTWARE + KEYGEN + PATCH ---- ECU Repair Guide Electronic Tool 2022 ---- BMW E-Sys 26.04.02 New Version MEGA ---- Best K-Suite Version For Kess 5.017 K-Tag 7.020 ---- Immo Doctor 2.1 + Multi Editor + DTC Off + Keygen ---- Subaru SSM3 Universal J2534 04.04 Patch Full ---- SCANIA SDP3 TRUCKS + MARINE + KEYGEN ---- CUMMINS INSITE 9.3.1-10.0-10.1 PATCH FIX TOOL ---- Iveco Power Trucks Buses 2020 Full MEGA ---- Lsuite 1.2 Checksum Tool Full ---- Ksuite For Ktag 7.020 ---- Lsuite 1.03 v2 Checksum Tool Full ---- PCMFlash ECU Master KTM 1.20 ---- DTS Monaco 9.04.16 Activation TOOL ---- NYO 4.0 (2017) Full + Pictures Tested Working ---- Hello from Germany ----
Mercedes
FullFix By Samik, easy Mercedes software installer
[Image: attachment.php?aid=15577]
Xentry activation working on Xentry 03.2021-03.2024 on Windows 10 64bit!!!
- Activate Xentry with offline account. (Just leave login and password fields blank, no need to write anythink)
- ENTRY Special Functions Keygen and DAS FDOK Keygen from benjaminjai.
- DAS Standalone & DAS Simulation, And fix Error (18).
- DAS Special Functions & password bypass..
- Prototype in DAS. Adding 166, 197, 204, 207 and 212 DAS Standalone (have to install DAS Standalone).
- Offline flash in DAS Standalone.
- HHTWin by Azzatec, modified by Samik.
- Ignition Enabler (if you use PassThru version).
- SEED Calculator UnlockECU.
- SeedCalc 3.0 от R00TR0w
- Vediamo 4.02.02 or Vediamo 5.01.01. Install and easy activation by Samik.
- SW Finder v5.2.
- VGSNAG2 Manager v1.6.
- DTS Monaco 8.16, install, Fix Blue Screen, 2 ways for activation and configs for VCX SE by Samik.
- DTS Monaco 9.02.
- Diagnose DoIP models with ENET cable for XDOS (working only with XDOS 09/21 - 03/24).
- Download Manager COMAND Hard-disc navigation from offitial website.
- WIS 07.2021 automatic activation, download link for WIS 07.2021 and config for starting it from Xentry.
- Fix for DTS Monaco 8 working with SDConnect C4.
- Fix for Xentry Update Service (XUS).
- A few ZenZefi After-Sales_STANDARD certificates.
- Simple IP Config for easy edit IP on Ethernet adapter.
- Install Openport 2.0 driver from official site.
- Install VX Manager
- Install Scanmatik 2 Pro driver from official website.
- MBTools.
- 7G SCN by Samik.
- SDConnect on Xentry 12.2023 and Daimler Truck.
- Secure boot in Bios must be DISABLED!!! (program check it and will ask you turn off it)
- Antivirus must either be DISABLED or you must set appropriate Antivirus exceptions to ensure that it does not interfere with the files!
Instructions for Xentry activation
Xentry activation never was so easy:
1. You have to install Xentry, restart PC.
2. Install FullFixBySamik (by chacked Activate Xentry)
3. Start Xentry from desktop icon.
It is done!
Us Xentry activation only in clean system and in clean Xentry!
I record a video how working my program (old version v4.5.6 XDOS), you can watch it here (click me) and with v4.6.8 (XPT) here (click me).
Price for program $25 for 1 PC.
Added new video in first post with version FullFix by Samik v4.5.6. All buges finded in video are fixed!
New update FullFixBySamik v4.6
- Updated XENTRY Special Functions Keygen v1.2.
- The certificate has been updated, the new one is valid until 01/31/2024.
- When installing UnlockECU, .NET Desktop Runtime 5.0.0 is installed immediately (no need to download and install separately anymore).
- Fixed a non-working icon for the folder with firmware from XUS.
Thanks given by: AUTOHEX
New updates
FullFixBySamik v4.6.4
- Fixed a small bug in Fix C4 Monaco
- DAS SDconnect WiFi Connection Respawn
- Now Fix C003 is launched immediately as an administrator.
FullFixBySamik v4.6.2
- Added two new After-Sales STANDARD certificates until 03/28/2024 and until 04/01/2024.
- Two files have been added to DAS Special Functions: flexab.s and flexua.s.
New update FullFixBySamik v4.6.5
- Added check update program for FullFix. Know all updates can be done without downlad and run 2.5Gb installation program.
FullFixBySamik v4.6.6
- There was bug with second time installation on one PC and it is fixed.
New update FullFixBySamik v4.6.7
- Added one more After-Sales STANDARD certificate.
- ConfigAssist removed from autorun.
- Now, when XUS is fixed, the command line window closes automatically.
- Fixed problem with installing J2534 switcher for Vediamo 4.
If you already have the fix installed, you can update from "Check updates" icon on your desktop.
New update FullFixBySamik v4.6.8
- Added translation of the activation request window.
- Added Scanmatik 2 / 2 Pro driver from the official website.
- Fixed a small bug from the previous version.
New update FullFixBySamik v4.6.9
- A fix has been added to the WIS Config Tool to remove the What's New window, which opens every time you start WIS. It can be found in the Start menu.
- The logic of the WIS Config Tool has been updated, now WIS activation will not fail after launching Xentry.
- Added MBTools program.
- Added a Fix that easily changes the EWA port to 9002. It can be found in the Start menu.
- Fixed problem with "Firmwares folder" shortcut.
FullFixBySamik v4.7
- Changed login information for Xentry. Now when you start Xentry, just leave the fields blank! You no longer need to waste time filling out these fields.
New update FullFixBySamik v4.7.1
- In the new Xentry 12.2023, the structure of ZenZefi has been changed and in this version it is not possible to import certificates using the old methods. A script has been added with which you can easily import certificates.
- Added picture GLB (248).
