Latest news: ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ---- Mercedes Gear Tool Full ---- Scania Xcom 2.54 + Plugin Full ---- GPEC2 GPEC2A FIRMWARES + KEYGEN ---- BMW ISTA-P 3.75.0.400 Modified ICOM A1 A2 Support ---- Complete Automotive Workshop Software Collection Full Version ----
XbusToolKit + XbusTRTool with Commands (Group Engineering Tools)
lfas Online
GM
GM Group Engineering Tools:
XbusToolkit + XbusTRTool + Commands = 60$
XbusToolkit – Supports J2534 Tools----------------------------------------------------
Second-hand module removal
Modify the frame number
Modify the mileage
Modify the security password
Radio unlock and other functions
Command sales... & more
[Image: GM-XBusToolKit-1024x622.png]
.[Image: XBusTRTool-1024x638.png]
LLCasaol Offline
(11-26-2022, 04:58 PM)lfas Wrote: XbusToolkit– Supports J2534 Tool
Modify the mileage
XbusToolkit +
GM Pro EMULADOR J2534 +
CC-CB calculator
the 3 costs 160$
___________________________________________________________________________________________________________________
[Image: 22112605231125315418058342.png]
[Image: 22112605233625315418058343.png][Image: 22112605233725315418058344.png]___________________________________________________________________________________________________________________
_ if you need GM DPS 4.51 & Patac DPS 2.0.7,---------------------------------------check here
_ if you need GM DPS Archive Creator Tool ( Converter of SPS to DPS calibrations),--check here
_ if you need Global-Tis for offline programming till 2012--------------------------check here
_ if you need GM GDS2 07.2020 final version, and Tech2win,----------------------check here
Regards, Lfas
https://automotiveforum.net/showthread.php?tid=12168
want this application,
libbservice Offline
Is Gm emulator work on EU SPS (not ACDelco Techline?
stephanec Offline
(11-26-2022, 04:58 PM)lfas Wrote: GM Group Engineering Tools:
Modify the mileage
need it!
Thanks given by: jacroaalcon
stephanec Offline
Modify the mileage
Need the software.
