Latest news: ---- Nexiq Etech 2.13 Setup File Needed ---- BMW ISTA Ilean 4.61.40 VOLTAGE PATCH TOOL ---- ATRIS Stahlgruber + Technik 2018 VM FULL ---- BMW ISTA VOLTAGE PATCH TOOL ---- Davinci 1.0.28 Unlocked Not Require Activation ---- Cnh Est 9.13 ---- Tuning Tool Tuner Calc UltraCuttr VMaxr InfoGrabbr Number ADDR QLaunchr ---- Xprog 5.55 ECU Programmer Tool ---- Multiprog Xhorse Patch FR Files ---- BOMAG EPC Wiring Diagram Service Manual FULL ---- JCB Service Master 4 v.1.24.5 Files MEGA ---- Nissan Consult 3+ J2534 VI2 VI3 VCI Files Full MEGA ---- MultiEcuScan 5.3 With KG Free For All ---- ECU TUNING SOLUTION FREE FOR ALL ---- Porsche PIWIS 4 Fix TOOL ---- Ford FJDS 133.01 + Patch Real Full ---- BMW ZGW CAN HACKER TOOL ---- BMW ISTA SQLiteDBs 4.58.30 PL MEGA ---- BMW ISTA GUI 2.1.0 New Update ---- VOLVO PTT 2.8.390 FILES INSTALLER MEGA ---- BMW ISTA+ 4.61.40 Standalone German English Full ---- Cummins Calterm Fix Tool ---- Eaton Service Ranger 4.2 + Keygen And Instruction ---- XDF A2L WinOLS Converter Tool FULL ---- Volvo APCI+ Database 09.2025 Files Mega ---- BMW Easy Connect 2 v1.5 TOOL ---- PIWIS3 VAS 6154 Clone Driver TOOL ---- WinOLS 5.67 ECU Tuning Hex Editor Tool ---- IMMO SERVICE TOOL 1.2 SOFTWARE 2017 + KEYGEN FULL ---- Iveco Daily VI Electrical Wiring Diagram Full ----
VAG ETKA 8.1 (1511) + 8.2 (1587) 01.2025) + 8.3 - Torrent (without pass)
VW
VAG ETKA 8.1 (1511)  + 8.2 (1587) 01.2025 + 8.3 - Torrent (without pass)
The ETKA electronic catalog contains complete information on spare parts and accessories for VAG vehicles (VW, Seat, Skoda, AUDI), including minibusses.
Works on Windows x32 and x64.
Patch and instruction inside.
Added new version VAG ETKA 8.1 (1432) 01.2022
Added VAG ETKA 8.2 (1474)
Thanks given by: WoodrowVam
trb.ro Offline
(11-25-2022, 06:38 PM)aleksey-ms Wrote: Added VAG ETKA 8.2 (1474)
Hello Aleksey,
 I have a hiccup with the installation. After everything is installed correctly by using the instructions .txt,  when i run Ekta, i get myself this message:
information über den vorhandenen Hardlock
Version der DLL 2.12
Beim Ansprechen des Hardlocks trat der Fehler 7 auf
Translation by the holy google:
information about the existing hardlock
version of the DLL 2.12
Error 7 occurred when addressing the hardlock
Tried the following steps to address the issue:
- performed an uninstallation of Ekta, with registry cleanup to ensure a clean entry of the reg files. (HKEY_CLASSES_ROOT, HKEY_CURRENT_USER, HKEY_LOCAL_MACHINE entries were deleted accordingly, and checking USERS & CURRENT_CONFIG revealed no extra reg entries)
- doublechecked for any residual files/folders
- reinstalled with the same error afterwards.
Tested on Win7 x64 hardcase laptop used primarily for auto diagnose for VAG cars (VCDS however is not yet present as it is a fresh OS install and i wanted to start off with EKTA before VCDS).
Please advise if you happen to know a way around this. I am sorely tempted to nuke and reinstall the OS but i'd love to avoid that Big Grin
Cheers from Bucharest!
Hello Aleksey,
Hello. There may be too many reasons for this error. If you need help installing, send me a PM.
Added VAG ETKA 8.1 (1485) + 8.2 (1487)
Added VAG ETKA 8.1 (1511)
VAG ETKA 8.2 (1587) 01.2025
D7I.c Offline
What's the password for version 8.3? Because it asks me to enter a password as soon as I install it.
