Latest news: ---- XDF A2L WinOLS Converter Tool FULL ---- Volvo APCI+ Database 09.2025 Files Mega ---- BMW Easy Connect 2 v1.5 TOOL ---- PIWIS3 VAS 6154 Clone Driver TOOL ---- WinOLS 5.67 ECU Tuning Hex Editor Tool ---- IMMO SERVICE TOOL 1.2 SOFTWARE 2017 + KEYGEN FULL ---- Iveco Daily VI Electrical Wiring Diagram Full ---- BMW ISTA 4.61.40 Works ICOM D-CAN ENET FULL ---- Scania SDP3 v2.72.2 Files MEGA ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- BMW Passthru PTD Driver 3.0.14.0 TOOL ---- BMW ISTA 4.61.4x VERSION AND I-LEVEL OVERVIEW ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- PIWIS License Manager TOOL ---- TOYOTA ISTA OFFLINE LAUNCHER TOOL ---- Cummins Insite 8.9.0.130 + Keygen And Instruction ---- Scania SDP3 v2.72.1 Files MEGA ---- BMW ISPI ISTA 4.61.40 PATCH TOOL ---- Hex-Rays IDA Pro 9.4 HF + Patch Keygen ---- Node Ediabas Voltage Control 4.28.40 To 4.37.30 ---- ODIS-S COMPLETE LATEST FILES MEGA ---- Toyota TechStream Plus 2026.03.102 Diagnostic Software ---- Fendt Service Manuals Collection Mega ---- NCS Expert Daten TOOL ---- hi all ---- Node Ediabas Voltage Control Tool ---- DIAGBOX v9.260 FILES FULL MEGA ---- Piwis online ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ----
Remote Install - DAF DAVIE XDC II, Developer Tool, Devik, Rapido
daf
Remote Install - DAF DAVIE XDC II Runtime 5.6 04.2019 + After Sales 95, Developer Tool, Devik, Rapido
DAF DAVIE 4 PACCAR MX-11, MX-13 for USA, Canada, Mexico (5 years license) - $4750
DAVIE 4 - PACCAR MX-11, MX-13 features:
Works on Peterbilt & Kenworth
Reflash ECU with new calibrations. Calibrations are accessible over-the-internet through the Davie 4 Software. There is not charge for PACCAR calibrations.
Perform and read all diagnostic tests
Enable Progressive Shifting
Enable Park Brake Reset
Enable Air Temp Idle Timer Override
Idle Time In PTO Mode
Enable Clutch Pedal Position Timer Reset Condition
Time Remaining To Shut Down After EIST Warning
Enable Accelerator Position (as timer reset condition)
Enable Foot Brake Position (as timer reset condition)
Enable Clutch Pedal (as timer reset condition)
Enable EIST in PTO mode
Read, reload & download all snapshot & trip reports
Read all chart recorder items
Read & clear all fault codes
Adjust road speed
Download all log files into Excel or PDF files
Diesel Particulate Filter Regeneration
Include Original Eportal With database access to change parameters (such as max vehicle speed) Online or reflash the electronic control module
Supports Nexiq Usb-Link 2.
[Image: daf-davie-4.jpg]
DAF DAVIE XDc II - $89
With the help of DAF DAVIE XDc II / DAF VCI-560 you can perform the following functions:
  • Identification of electronic control units
  • Reading, erasing errors
  • Testing of actuators
  • Visualization and evaluation of current signals from sensors received by the ECU
  • Guided troubleshooting
  • Control of technical condition and service functions
  • Coding and replacement of control units.
[Image: DAF-DAVIE-XDC-Runtime.jpg]
DAF Developer Tool - $99
DAF Developer Tool - calculator for obtaining the codes necessary to open an additional level of access in the DAF Davie XDc II Runtime program, access to programming control units and changing the V-max parameter (speed limit)
The functionality of the DAF Developer Tool:
  • DMCI programming (engine management system)
  • ECSDC3 programming (DAF-Cummins 3 engine management system)
  • ECSDC4 programming (common rail diesel injection system)
  • ECSDC5 programming (common rail diesel injection system)
  • PMCI programming (PACCAR Multi-Control Injection 2013-2015 engine control unit)
  • PMCI2 programming (PACCAR Multi-Control Injection 2010-2012 engine control unit)
  • UPEC programming (injection control system)
  • password generation to change the maximum speed of the truck (30-140 km)
  • turn on / off EOL (End Of Line)
  • generating passwords for entering the "Service Level - Service Level" - to obtain advanced rights and functions when using the diagnostic program DAF Davie XDc II Runtime).
DAF XF 95, XF 105 Configuration Files - $149
  • DAF XF 95 Configuration Files for Replacement Automatic Transmission to Mechanical Transmission
  • DAF XF 105 Configuration Files for Replacement Automatic Transmission to Mechanical Transmission
  • DAF XF 95 Configuration Files Power off Retard for Automatic Transmission
  • DAF XF 105 Configuration Files Power off Retard for Mechanical Transmission
DAF Devik Configurator - $99
DAF Configurator (Devik) - Specialized DAF Truck Software
Functionality:
  • Disabling AdBlue
  • Power increase
  • Russification of the dashboard
DAF Rapido - $55
The spare parts catalog for DAF trucks and buses contains complete information on all series of trucks, starting from the 70s, as well as information on axles and suspension of trailers (BPW, ROR, SAF, Trailor, Fruehauf). DAF RAPIDO is supplied on three to five CDs or one DVD, with full installation it occupies 6.5 Gb, in addition, to spare parts, the program contains a catalog of accessories and additional equipment, as well as catalogs of axle parts and suspension for semi-trailers. The program has a full VIN decryption, search by VIN, model, engine number, name, or part number. In addition, the DAF RAPIDO program has very useful functions, but extremely rare in the programs, then comparing the original part numbers of two different chassis numbers and translating O.E.M. manufacturers (applied on DAF) to the original numbers.
DAF Davie developer tool 0.3.1 + USB dongle - $770
DAVIE DevTool 0.3.1 features:
  • Passwords for programming Crashed units and New units
  • Supported old/new calculation types of passwords for programming
  • Retrieve Customer Password for PCI and PMCI2 units
  • Get password for programming V-MAX (speed limit)
  • Enable/Disable EOL (End Of Line) mode
  • Supported old/new passwords to login to Service Level for more rights.
[Image: DAF-Davie-developer-tool-0.3.1.jpg]
DAF Truck Tools - $2450
It designed to change the parameters and performance of DAF vehicles.
Parameters and functions:
Deactivation of power and speed limits in the event of a malfunction of the AdBlue system
Pre-injection
Water pump
Humidity sensor
lambda probe
EGR valve
BPV valve
Ventilation of crankcase gases
Idle timer
AdBlueOFF Euro6.
Also to work on it you need to have installed DAVIE 3 diagnostic software.
[Image: 1.png]
DAF LF 45 - 55 Workshop manual - $35
DAF XF-CF Euro 6 Workshop/Diagnostic Manuals, Diagrams - $75
Added DAF Truck Tools
