Latest news: ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ----
Xentry OpenShell 09.2023 and 12.2023 HHTwin DAS WIS EPC STARFINDER VEDIAMO MONACO
Mercedes
Xentry OpenShell 09.2023 (Cars and Trucks) and 12.2023 (Cars) HHT DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis)
Need it? Push buttons Rate (Reputation) and Thanks, PM (write in Private Messages) for pass.
Questions about the password, write in a personal.
Asking for a password in a topic will be ignore.
[Image: e1cc88423940d1a865c9f092fd17a29b.jpg?r=1]
  • Year / Release date: 12.2023
  • Version: XDOS 23.12.4
  • System requirements: Laptop not older than 2010 + HDD or SDD >= 480 Gb, 4GB RAM
  • Interface language: Multilingual
  • Activators: present
Description: Acronis disk image with Windows 10 LTSC x64 ENGLISH, contains both Legacy and UEFI bootloaders. The image of programs for diagnostics, coding and programming of cars of the Mercedes-benz concern.+Strelec WinPEAdd. Information: The image contains EVERYTHING you need to activate and configure, for FULL FUNCTIONALITY!
If you want me to personally carry out all activations, write in private. I do activation by a long key. Additionally, I can install certificates for cars manufactured from 2021 of release 223 and 206, EQE, EQS,...
The software package in this image is already configured for MB Star C4 (Mercedes Star Diagnosis Compact 4)
I will configure and activate under C3 (virtual machine with version 09.2014), C4, C5, C6, Xentry VCI
New projects for DTS Monaco 2023 were added to the assembly. Automatic blacklist and offline login protection was introduced. Solution for Xentry Trucks offline mode has been fixed. A new XUS has been activated. This assembly is a refinement and modification of the 06.2022 image, it is fully configured for offline, all offline patches are applied and additional ones are activated. functions for DAS. Applied patch for Xentry Offline Login corrects program closure and allows diagnosing w167, w213 rest, x290. Applied patches for special functions of trucks in DAS (Vmax, Max Torque, Erase SCR Adblue and others). A data map has been configured in WIS and EPC, as well as shortcuts for direct launch.
Software versions:
Xentry offline login (just click LOGIN)
DAS SCN offline coding (SDFlash 07.2018)
Xentry OpenShell 09.2014 (Virtual machine for full C3 support)
Xentry Update Service 6.9.0.0
Vediamo v05.01.01 Level 10
DTS Monaco v8.14.016 + projects 2023 (8.16.015 as a bonus upon my activation) + setting for C6, Xentry VCI, VCX SE + setting for J2534
DTS Monaco v9.02
EPC 2018/11
WIS 2020/10
WIS standalone 2021/07
COMAND Download Manager 2.0.0.6
StarFinder 2016 (with wiring diagrams) + WEB_ETM 2024
HTTwin direct installation with full functionality
DAS FDOK Keygen
MBSeedKey+DLLs 2020
Seed Calculator + DLLs 2020
DisassemblyAssistant
Regio ECU 09.2014
VGSNAG2 Manager v1.6
Manuals for Vediamo and DTS Monaco
Push buttons Rate (Reputation) and Thanks.
Xentry OpenShell 06.2023 HHT DAS WIS EPC STARFINDER VEDIAMO MONACO + Certificate (Acronis)
Thanks given by: outubro , outubro
Mercedes
plikisx1 Offline
Software versions:
DTS Monaco v9.02
EPC 2018/11
WIS 2020/10
DAS FDOK Keygen
MBSeedKey+DLLs 2020
Regio ECU 09.2014
plase password
Thanks given by: Simon2026
