Latest news: ---- SCANIA SDP3 V2.70.1.3 FULL TRUCKS + MARINE + KEYGEN ---- BMW ISTA Updater GUI 2.0.0 TOOL ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ---- VCM EDITOR COLLECTION FULL ---- VCDS Release 26.3.0 VIIPlus Loader 08.026.08 FULL ---- Winols 4.7 With Installer Full Mega ---- BMW CAS4+ EDITOR TOOL FULL ---- BMW ISTA 4.61.1x VERSION AND I-LEVEL OVERVIEW ---- ProSeCco Data Time Tool Full ---- CDA 6-J2534 bridge (Dubb45 Tool to use CDA with Passthru) ---- Subaru SSM4 Universal J2534 + Patch Full ---- Xentry Full Fix 4.9.8 Soft Easiest Installation Activation ---- Diagbox 7.57 Pack Complete Full ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 + Fix Last Update ---- GM ECU FLASHER TOOL FULL ---- Hino DX3 v1.25.1 Diagnostic Solution Files Mega ---- Winols EDC15 Mappack Generator TOOL ---- xDecoder + Keygen 100% Work ---- VAG PCR 2.1 DECODER TOOL FULL ---- SDD use for LR Discovery 4 ---- Toyota Lexus GTS+ 2026 Offline Diagnostic Software ---- ECU Tuning Solutions + Keygen IMMO DTC EGR DPF ADblue OFF ---- BMW PSdZData 4.61.11 Torrent File FULL ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ---- BMW ISTA Czech Database 4.57.XX 4.61.XX MEGA ----
Added Ford IDS 129.03
Added Ford FDRS 35.5.4
Thanks given by: jackm44 , jackm44
VTrifonov Offline
(11-26-2020, 02:09 PM)aleksey-ms Wrote: Ford IDS 129.03 + FJDS 129.01 + FDRS 35.5.4 + Mazda IDS 129 - for VCM2 / J2534
Hello, can I have the password (I gave you Thanks and Rate (Reputation))
ECARFRANCE Offline
#95
(11-26-2020, 02:09 PM)thank you for sharing can you give me the password pleasealeksey-ms Wrote: Ford IDS 129.03 + FJDS 129.01 + FDRS 35.5.4 + Mazda IDS 129 - for VCM2 / J2534
gltcls8 Offline
Ford
(11-26-2020, 02:09 PM)阿列克谢-MS Wrote: 福特 IDS 129.03 + FJDS 129.01 + FDRS 35.5.4 + 马自达 IDS 129 - 适用于 VCM2 / J2534
IDS。IDS为所有1996年选择的2018年福特,林肯,水星车辆提供完整的经销商级车辆诊断服务。IDS需要使用福特诊断硬件,包括VCM,VCM II和VCMM设备。IDS 软件许可证包括对 IDS 软件、软件更新、校准文件的基于时间的访问。
FJDS提供涵盖1996年选择2018年福特、林肯和水星模块重新编程功能的模块重新编程软件,以及适用于所有2018年福特和林肯车辆的完整经销商级诊断软件。FJDS设计用于J2534兼容的车辆通信接口(VCI),包括福特诊断硬件(VCM II或VCMM)。FJDS 软件许可证包括对 FJDS 软件、软件更新和校准文件的基于时间的访问。
FDRS - 福特汽车公司的下一代工厂车辆诊断软件,设计用于兼容 VCM II、VCMM 和 J2534 的 VCI。FDRS为一些2018年和未来的车辆提供完整的经销商级车辆诊断保险。FDRS 提供卓越的功能,更加用户友好,并提供比 IDS 更多的诊断工具。基于云的系统确保每次FDRS登录福特网络时都能为技术人员提供最新的软件。
需要吗?按钮 评价 (声誉) 和 谢谢, 下午 通过
Added Ford IDS 129.04
Added Ford FDRS 35.5.5
Added Ford IDS 129.05
Thanks given by: LOUISe , LOUISe , Thomasten
11 Guest(s)
