Latest news: ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ----
Toyota, Lexus Reprogramming / Calibration CUW files
Flash reprogramming allows the ECU software to be updated without replacing the ECU. Flash calibration updates for specific vehicle models/ECUs are released as field-fix procedures described in individual Service Bulletins. This bulletin details the Techstream ECU flash reprogramming process and outlines the use of the Technical Information System (TIS) and the Calibration Update Wizard (CUW). Flash calibration updates can only be applied to the vehicle/ECU combination for which they are intended. ECUs have internal security that will not allow them to be programmed with another ECU’s information.
[Image: Toyota-Lexus-Reprogramming-Calibration-CUW.jpg]
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
The link was updated
Thanks given by: XRumerTest , RidgecokS , DavinJOb , Galenot
holdenking Offline
(04-11-2022, 04:56 PM)aleksey-ms Wrote: Toyota, Lexus Reprogramming / Calibration CUW files
hi pass please
Added Toyota Corolla 2009 302a4200 + Calibration Supersession Notice
Thanks given by: Keganguew , RidgecokS
hi pass please
Thanks given by: RidgecokS , Galenot
Markx880224 Offline
may i hv pass pls
Thanks given by: Galenot , RidgecokS
may i hv pass pls
Thanks given by: DavinJOb , RidgecokS
Namacha2009 Offline
pass?
pass?
Namacha2009 Offline
What is the code?
What is the code?
Thanks given by: Galenot , RidgecokS , DavinJOb
