Latest news: ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ---- VCDS LASTEST VERSION FILES MEGA ---- ECM Titanium 40.000 Drivers Chip Tuning Firmware Editor ---- UPA SOFTWARE + SCRIPTS COLLECTION FULL ---- Ecu Connections All Cars Tool ---- DTS Monaco 9.02 + Patch + Keygen + Projects Full ---- Easy Kill v2.0 Start-Stop Off Tool ---- iDecoder 4.5 Ultimate Automotive ECU Immo Solution ---- ECU Repair Guide 2022 TOOL ---- Challenger TerraGator 3244 Service manual ---- JPRO 2026 v1.1 WITH ACTIVATION FULL ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ----
AlfaOBD 2.4.4.0 for PC + AlfaOBD 2.3.3 for Android
Alfa
AlfaOBD 2.4.4.0 for PC + AlfaOBD 2.3.3 for Android Patched
AlfaOBD is a software for the diagnostics of the vehicles produced by Fiat Chrysler Automobiles (FCA) group. Fiat / Alfa Romeo / Lancia, Chrysler / Dodge / Ram / Jeep. Although the software is primarily targeted for car owners, it provides many of the features of the professional scanners.
The software supported:
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
  • K-Line USB interface.
AlfaOBD features include:
  • monitoring various dynamic parameters of the body, dash, code, engine, gearbox, ABS, climate control, etc. and graphical presentation as adjustable plots.
  • reading of static data: ECU id, system status, fault codes with probable causes and environment information where applicable.
  • clearing fault codes, monitoring the system for the appearance of new faults.
  • active diagnostics and configuration procedures for various equipment controlled by engine, gearbox, body computer, climate control, ABS, airbag, code control, other ECUs. Service light reset, engine oil change, DPF regeneration and many more.
  • electronic key and RF remote control programming.
[img]I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.[/img]
Added a new version - AlfaOBD 2.1.9.6 (for Android) Patched
Added a new version - AlfaOBD 2.2.1.0 (for Android) Patched
Added new version AlfaOBD 2.2.5.0
Thanks given by: Kompel , Kompel , symace
Added new version AlfaOBD 2.3.5.0
(08-26-2022, 02:38 AM)raulinonog Wrote:
(06-24-2022, 07:49 PM)aleksey-ms Wrote: Adicionada nova versão AlfaOBD 2.3.5.0
Olá qual é a senha de descriptografia do download ????
Thanks given by: lindonato , ADMilstead , ADMilstead
Memoli Offline
(08-18-2020, 10:23 AM)aleksey-ms Wrote: Thank You !
Password please Smile
AlfaOBD 2.3.5.0 (for Android) Patched
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
[Image: AlfaOBD.jpg] [Image: AlfaOBD-.jpg]
  • OBDLink
  • OBDKey
  • ELM327
  • Kiwi 3
Thanks given by: fasda1984 , fasda1984
fasda1984 Offline
mega pass please??
yabec2005 Offline
thanks please pass
