Latest news: ---- BMW ISTA Voltage Terminal Warning Disabler TOOL ---- PCR2.1 UNLOCKER TOOL FULL ---- IMMO Universal Decoding 3.5 Delete IMMO OFF ECU ---- BMW Easy Connect 2 v1.6 TOOL ---- Cmp Hex Tool Full ---- DTS Monaco 9.02 + Keygen + Patch FULL ---- Mercedes Gear Tool Full ---- Scania Xcom 2.54 + Plugin Full ---- GPEC2 GPEC2A FIRMWARES + KEYGEN ---- BMW ISTA-P 3.75.0.400 Modified ICOM A1 A2 Support ---- Complete Automotive Workshop Software Collection Full Version ---- Automatic Transmission Repair Manuals Rebuild Parts ---- BMW ISPI ISTA Launcher Offline Version MEGA ---- Bosch ESI [tronic] 2014 DVD1+DVD2+DVD3 Diagnostic Software ---- L-Suite Checksum Tool 1.03 Full Pack With KSuite DLLs ---- Actia Multidiag J2534 PassThru Support Full ---- hello from norway ---- Cummins Insite 9.3.0.22 Files Mega ---- SWFinder 6.1.8 File MEGA ---- ISTA iLean Voltage 4.61.40 No License No ISPI Admin Client ---- BMW ETK Price 10.2026 ---- Multi Editor Honda Tool Full ---- ECU Circuit Diagram Bosch Schematic ---- BMW FSC GENERATOR MG1 MD1 MSD DME TOOL ---- Wabco Calculator PIN1-PIN2 Activator Keygen ---- BMW Immo Off BTT EWS Deleter v1.1 Immobilizer TOOL ---- Alex Flasher + Keygen Full Version ---- Nexiq Etech 2.13 Setup File Needed ---- BMW ISTA Ilean 4.61.40 VOLTAGE PATCH TOOL ---- ATRIS Stahlgruber + Technik 2018 VM FULL ----
VAG DPF 3.40.12 Full (for Android device + ELM37)
VW
With this application you can find out if the filter is really in the process of regeneration, if the regeneration is awaiting completion, how many kilometers have you traveled since the last regeneration, etc.
Core functions:
  • Display of 12 DPF filter parameters like soot mass accumulation in the filter, regeneration duration, km traveled and time passed since last regeneration, EGR valve closing, exhaust gas temperatures of the inlet, and outlet of DPF (Attention: data shown may vary depending on the engine type due to the presence of the parameters into the engine ECU)
  • Manual or automatic parameters update
  • Display, for all the parameters, of the previous value and the difference between the actual and the previous value (only for automatic update delays different from 0 seconds)
  • Ability to exclude one or more parameter to increase the reading speed
  • Display of the filter filling percentage before reaching the filling limit that starts the execution of a field regeneration (standard regeneration controlled by the engine ECU)
  • Graphical display, using a progress bar, of the filling percentage value before starting a field regeneration or a service regeneration
  • Graphical display of the filter status: red filter for the regeneration phase (passive, field, or service) of the grey filter with different back internal areas depending on the filling percentage value
  • Display of extra data: adapter communication error counter, filter filling rating in µg/min, update time of all the 12 parameters, automatic update delay actually selected in the options menu
  • Notification bar icon to show an active connection and the auto-update process running.
[Image: VAG-DPF-3.3.jpg]
Added a new version - VAG DPF 3.18.8
What's new:
- added DAVA engine to group 15
- added CKFC engine to group 0
- added CRCA engine to group 17
Added new version VAG DPF 3.20.9 Full
Whats new:
-- correct an issue in group 18
Added new version VAG DPF 3.22.10
Added VAG DPF 3.25.10 Full
Added new version - VAG DPF 3.26.11
Added VAG DPF 3.27.12
Added VAG DPF 3.28.12 Full
marmavag Offline
(04-19-2021, 11:06 AM)aleksey-ms Wrote: Added a new version - VAG DPF 3.18.8
What's new:
passwd please
What's new:
passwd please
