Latest news: ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 FULL ---- TOYOTA DENSO ECU IMMO DTC FILES MEGA ---- Xentry SDconnect Toolkit Fix 09.2026 ---- XENTRY RELEASE 4 - 09.2026 FILES ---- SRS AIRBAG CRASH KILLER + KEYGEN FULL ---- Kraken Auto Database ECU Tool ---- Autotuner File Converter Tool ---- SDT-II 2.43.0.126 Files MEGA ---- MUT-III PassThru 26061-00 Files MEGA ---- BMW ISTA GUI 2.1.0 NEW UPDATE ---- Scania DEC2 Engines Control System Software Files ---- BMW ISTA 4.57.21 Polish Language ---- BMW PSdZData 4.61.30 Files FULL ---- FVDI Software Download Files MEGA ---- FTAG 1.1.0 Checksum Correction Tool MEGA ---- All BMW Maps In One Place Files Torrent ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ---- ODIS 26 + Patch ---- Unlock ECU Seed key Calculator TOOL ---- ZOOMLION ZCC550V MANUAL NEED HELP ---- XENTRY XDOS XPT 09.2026 FILES MEGA ----
2021.07 WIS
benz Y Offline
Mercedes
2021.07 WIS
benz Y Offline
(04-02-2022, 12:46 PM)otoeko Wrote:
(04-01-2022, 12:31 PM)benz Y Wrote: 2021.07 WIS
Thanks for your sharing. When I enter the disk, there is no setup or run file, how can I install it?
Ewa Admin Tool ?
Select the EWA folder, then xd_pad to find the installer
Thanks given by: Robertjax
yuse878 Offline
hi,
I having this error
com.install4j.runtime.beans.actions.control.runscriptaction failed confluence
after install in a new fresh install window 10 64Bit
The side bar option don't had wis option,only SSL & WSM?
May I know the procedure of installing the wis?
Thank you~
Search in forum forking very bad. A week i am looking for that, but could not find.
Today i have find it, in another forum and find this post just after search in google problem with com.install4j.runtime.beans.actions.control.runscriptaction failed confluence.
Anyway, thank to author.
(04-06-2022, 12:45 AM)yuse878 Wrote: hi,
I having this error
Thank you~
You have to activate it. You need this post.
