Latest news: ---- XDF A2L WinOLS Converter Tool FULL ---- Volvo APCI+ Database 09.2025 Files Mega ---- BMW Easy Connect 2 v1.5 TOOL ---- PIWIS3 VAS 6154 Clone Driver TOOL ---- WinOLS 5.67 ECU Tuning Hex Editor Tool ---- IMMO SERVICE TOOL 1.2 SOFTWARE 2017 + KEYGEN FULL ---- Iveco Daily VI Electrical Wiring Diagram Full ---- BMW ISTA 4.61.40 Works ICOM D-CAN ENET FULL ---- Scania SDP3 v2.72.2 Files MEGA ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- BMW Passthru PTD Driver 3.0.14.0 TOOL ---- BMW ISTA 4.61.4x VERSION AND I-LEVEL OVERVIEW ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- PIWIS License Manager TOOL ---- TOYOTA ISTA OFFLINE LAUNCHER TOOL ---- Cummins Insite 8.9.0.130 + Keygen And Instruction ---- Scania SDP3 v2.72.1 Files MEGA ---- BMW ISPI ISTA 4.61.40 PATCH TOOL ---- Hex-Rays IDA Pro 9.4 HF + Patch Keygen ---- Node Ediabas Voltage Control 4.28.40 To 4.37.30 ---- ODIS-S COMPLETE LATEST FILES MEGA ---- Toyota TechStream Plus 2026.03.102 Diagnostic Software ---- Fendt Service Manuals Collection Mega ---- NCS Expert Daten TOOL ---- hi all ---- Node Ediabas Voltage Control Tool ---- DIAGBOX v9.260 FILES FULL MEGA ---- Piwis online ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ----
Remote Install - Scania Multi, SDP3, XCOM, BNS II Service Tool (BST)
Remote Install - Scania Multi, SDP3, SDP2, XCOM, BNS II Service Tool (BST)
Scania Multi 10.2024 online (via remote desktop) 12 months - $135
Scania Multi 10.2024 online (via remote desktop) 3 months - $59
Scania Multi 10.2024 online (via remote desktop) 1 month - $35
Scania Multi 03.2024 - $190
Scania Multi 2022 - $65
Scania Multi 2020 - $35
Scania Multi is a car dealership aftermarket service. The program contains a catalog for the selection of spare parts and electronic manuals for repair and maintenance. Scania Multi works by VIN code and uses only the last 7 digits to decrypt the wines of a bus or truck. In the program there is a search by the part number, you can find out its applicability, as well as get information about the re-release of parts.
[Image: Scania-Multi.jpg]
Scania SDP3 2.58.3 Truck, Bus, Marine (with keygen) - $299
Scania SDP3 2.60 Truck, Bus, Marine - $155
Scania SDP3 2.54 for Truck and Bus (with keygen) - $155
Scania SDP3 2.64.1 Truck, Bus - $165
Scania SDP3 2.48 2021 - $35
SDP3 - Scania Diagnos + Programmer 3 (SDP3) software is designed for the diagnosis of Scania trucks and Scania industrial and marine engines. Connection to the electronic control units is done using the Scania VCI 2 or Scania VCI 3 interfaces. Depending on the version of the program, it supports work with all Scania trucks manufactured from 2004 to the present day.
[Image: Scania-SDP3.jpg]
Scania XCOM - $29
Scania XCOM - is a diagnostic tool to read, save, and modify ECU data such as trouble codes, parameters, statistic data etc. VCI2/VCI3 interface is used to connect to ECU via CAN protocol.
Supported modification of ECU data of the following types:
  • EMS – Engine management system
  • GMS – Gearbox management system
  • RET – Retarder system
  • AWD – All-wheel drive system
  • CLS – Clutch Control
  • EEC – Exhaust Emission Control
  • COO (COO7) – Coordinator
  • BWS (BCI1) – Bodywork system.
[Image: Scania-XCOM.jpg]
Scania Developer (CDEV - ECOM - XCOM) - $299
Scania CDEV supports the following operations:
  • Read ECU ID, data, parameters, fingerprint.
  • Read and erase DTC.
  • SparePart program all systems.
  • Gather all data for field test functions.
  • Load, modify, compare SOPS files.
Scania ECOM - is a program that, together with the VCI2, enables the communication between your PC and the control unit (EMS S6) on the engine.
You can carry out the following operations with ECOM:
  • Read stored fault codes and Freeze Frames.
  • Clear inactive fault codes.
  • Read information about stored working cycles.
  • Measure internal variables such as the engine speed, pressure, temperature and save them to a file.
  • Program certain parameters.
Scania BNS II Service Tool (BST) - $39
Scania BNS II Service Tool (BST) is a PC-based diagnostic program for troubleshooting and programming of the electrical system in the bodywork of Scania OmniCity, OmniLink, and Citywide buses.
[Image: Scania-BNS-II-Service-Tool-BST.jpg]
Scania SOPS - $59
The program encrypts/decrypts SOPS files (contains data on parameters and specifications of all blocks of trucks or buses). Files can be downloaded using Scania VCI2.
Scania SOPS Editor Euro-6 2022 Unlimited - $570
Supports EURO 6 Scania Sops File Encryptor/Descriptor.
  • Disable AdBlue
  • Disable EGR
  • Disable Immobilizer
  • Change VIN
  • Disable Nox Control
  • Disable Torque Reduction NOx Control
  • Disable Modify more than 300 other parameters...
    [Image: Scania-SOPS-Editor-Euro-6.jpg]
    Scania AdBlue Off Remover with short instructions - $45
    [Image: Scania-Ad-Blue-Off.jpg]
    Scania IMMO Pin Code Decryption 4.02 (activation 1 PC) - $165
    Scania IMMO Pin Code Decryption 6 (activation 1 PC) - $215
    Scania IMMO Pin Code Decryption 5 (activation 1 PC) - $189
  • It works with - ASSY, COO6, COO7, COO8, EMS S6/S7/S8/EMD1, LAS1/LAS2
    [Image: Scania-IMMO-Pin-Code-Decryption.jpg]
  • Need it? Write to me to discuss.
Scania SDP3 2020
Scania SOPS
Added Scania SP2, SD2
Added Scania Multi 2021
Scania Multi 10.2021 online (via remote desktop) 12 months
Scania Multi 10.2021 online (via remote desktop) 3 months
Scania Multi 10.2021 online (via remote desktop) 1 month
Added Scania Multi 2022
Scania SDP3 2.51 2022 Engine Marine Industrial, Truck Bus
Thanks given by: TALLERARGA
Added Scania SDP3 2.52
Added Scania Diagnos & Programmer SDP3 2.52
Scania SDP3 2.53.3 for Truck and Bus (with keygen)
Scania SDP3 2.53.3 for Engine Marine Industrial (with keygen)
11 Guest(s)
