Latest news: ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ----
vocom II mini not detected by techtool
translucian Offline
I bought a new original vocom 2 mini with wifi only.
I tried to pair it successfully with vocom II monitor and it worked,
I use only acces point mode and set mapping in different modes for it to be availible.
The issue is the unit does not pass communication to vehicle j...protocol and techtool sais that there is no vocom II tough connected.
Has anybody figured this out ?
Thanks given by: Smer4dsn , Rayzen , bungee83 , DANI1980
ied99 Offline
(11-11-2021, 06:51 PM)translucian Wrote: Hello,
DID YOU FIX TAHT I HAVE THE SAME PROBELM PLASE!
ADS69 Offline
Hi,
Your problem is most likely not with the Vocom itself, but rather with the configuration or compatibility.
Here are the most probable causes:
PTT version too old → the Vocom II Mini is only recognized from version 2.8 onwards. If you're on 2.7 or earlier, it will never be detected.
Wi-Fi mode → in access point mode, the software doesn't recognize it properly. Put it in Client mode (so it connects to the same Wi-Fi network as your PC).
Drivers → check in Device Manager that you have "Vocom II Mini Ethernet Adapter". If not, reinstall the drivers via the Config Tool.
Vehicle protocol → the Mini doesn't always support J1708 (only CAN/J1939). If your truck is a bit older, that might be the issue.
Try this first, but in my opinion it's either the PTT version or the Wi-Fi mode.
Thanks given by: MizteriouzA , motya , ZAGO , byarifo , lordhaos00 , Frankywaf
