Latest news: ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- BMW Passthru PTD Driver 3.0.14.0 TOOL ---- BMW ISTA 4.61.4x VERSION AND I-LEVEL OVERVIEW ---- BMW E-Sys Launcher PRO v2.8.1 + Token Generator ---- PIWIS License Manager TOOL ---- TOYOTA ISTA OFFLINE LAUNCHER TOOL ---- Cummins Insite 8.9.0.130 + Keygen And Instruction ---- Scania SDP3 v2.72.1 Files MEGA ---- BMW ISPI ISTA 4.61.40 PATCH TOOL ---- Hex-Rays IDA Pro 9.4 HF + Patch Keygen ---- Node Ediabas Voltage Control 4.28.40 To 4.37.30 ---- ODIS-S COMPLETE LATEST FILES MEGA ---- Toyota TechStream Plus 2026.03.102 Diagnostic Software ---- Fendt Service Manuals Collection Mega ---- NCS Expert Daten TOOL ---- hi all ---- Node Ediabas Voltage Control Tool ---- DIAGBOX v9.260 FILES FULL MEGA ---- Piwis online ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 FULL ---- TOYOTA DENSO ECU IMMO DTC FILES MEGA ---- Xentry SDconnect Toolkit Fix 09.2026 ---- XENTRY RELEASE 4 - 09.2026 FILES ---- SRS AIRBAG CRASH KILLER + KEYGEN FULL ---- Kraken Auto Database ECU Tool ---- Autotuner File Converter Tool ---- SDT-II 2.43.0.126 Files MEGA ---- MUT-III PassThru 26061-00 Files MEGA ----
Remote Install - Cummins Insite, Calterm, QuickServe, Incal, Inpower, PowerSpec
Cummins
Remote Install - Cummins Insite, Calterm, QuickServe, Incal, Inpower, PowerSpec, Wiring Diagram
Cummins Insite 9.1 Pro level + Fleet calibration + Zapit Password (without calibration files, with USB dongle) - $455
Cummins Insite 9.1 Pro level + Fleet calibration + Zapit Password (with calibration files) - $325
Cummins Insite 9.1 Pro level + Fleet calibration + Zapit Password (without calibration files) - $199
Cummins Insite 9.0 Pro level + Fleet calibration + Zapit Password (with calibration files) - $300
Cummins Insite 9.0 Pro level + Fleet calibration + Zapit Password (without calibration files) - $175
Cummins Insite 8.92 Pro level + Fleet calibration + Zapit Password (with calibration files) - $260
Cummins Insite 8.92 Pro level + Fleet calibration + Zapit Password (without calibration files) - $135
Cummins Insite 8.9 Pro level + Fleet calibration + Zapit Password (without calibration files) - $199
Cummins Insite 8.7 Pro level + Fleet calibration + Zapit Password (with keygen) - $470
Cummins Insite 8.7 Pro level + Fleet calibration + Zapit Password (with calibration files) - $200
Cummins Insite 8.7 Pro level + Fleet calibration + Zapit Password (without calibration files) - $75
Cummins Insite 8.6 Pro level + Fleet calibration + Zapit Password (with calibration files) - $180
Cummins Insite 8.6 Pro level + Fleet calibration + Zapit Password (without calibration files) - $55
Cummins Insite 7.6.2 (with calibration files) - $165
Cummins Insite 7.6.2 (without calibration files) - $90
Fix v3 for Cummins insite 8.7.086 Zapit for unlock ECM - $199
The functionality Cummins:
  • Reading, decoding, and resetting DTC diagnostic trouble codes.
  • Reading and displaying parameters on a PC screen from ECU sensors in real-time.
  • Testing and activation of actuators.
  • Adaptation functions.
  • Programming electronic control units.
  • Reset service intervals and more.
Cummins Insite Cal Fix v2 - $55Cummins Insite Cal Fix v3 (with keygen) - $699Cummins CalDL - $649
The tool for downloading incal files. it works independently of the Insite. If there is a problem in the mismatch between the date and the Insite program, you need to install Fix v2
[Image: Cummins-Cal-DL.jpg]
Cummins Calterm base of meta, delete files ECFG, E2M 2023 - $415
Cummins Calterm 5.16 + MetaFiles (with locked keygen) - $795
Cummins Calterm 5.16 + MetaFiles - $155
Cummins Calterm 5.2 + MetaFiles - $75
Cummins Calterm 4.7 + MetaFiles - $55
Cummins Calterm 3.6 + MetaFiles - $40
Cummins Calterm Deletes ECFG's base of metafiles - $199
Cummins Calterm 50Gb base of meta and delete files ECFG, E2M 2022 - $265
The program for the diagnosis of Cummins engines. Calterm is an engineering development tool used to monitor Electronic Control Modules for Cummins engine systems and to alter the calibration data contained therein. Calterm is designed to modify fueling calibration parameters and feature settings in engineering development and test environment.
Cummins Calterm Master Tool 9.2 2023 - $115
It's allow to use two Calterm versions on the same PC
[Image: Cummins-Calterm.jpg]
Cummins Insite 8.9, Calterm 5.11, Etool Holset, Jammer, Nemesis (with updates for 1 year) Pro versions - $650
Works like original activation.
Cummings ISX CM2250 15L DPF, EGR, SCR Delete - $185
Included bootloader/ECFG file for configuration, complete stock file, and complete performance DPF, EGR, SCR delete.
Cummings CM2250 12L DPF, EGR, SCR Delete - $185
Cummings ISLe 8.9 CM2150 Euro 4.5 Adblue Off - $45
Cummings ISX CM870 EGR Delete - $79
Cummings CM2250 CPL 3491 484hp Non Vgt - $59
Cummings CM2250 CPL 3491 600hp Non Vgt 25000TQ - $59
Cummings ECFG CM871 DPF Delete - $79
Cummings ECFG CM871 EGR Delete - $79
Cummings ISB CM850 EGR Delete EC2 - $79
Cummings ISX CM2350 DPF Delete - $79
Cummins QuickServe Online 1 Year Subscription - $1550Cummins QuickServe Online 1 Month Subscription - $330Cummins QuickServe Online 1 Week Subscription - $85These subscriptions offers following:
  • Electronic Service Manuals
  • Parts Catalogs
  • Wiring Diagrams
  • Serial Numbers - Unlimited
Cummins QuickServe 2017 - $75
QuickServe DVD - Power Generation Edition - Cummins ONAN 2017 spare parts catalog, service manuals, installation manuals, operator manuals, owner manuals, standard repair times, PDF.
[Image: Cummins-QuickServe.jpg]
Cummins INCAL + configure it in Insite - $45
Calibration files for Cummins engines.
[Image: Cummins-INCAL.jpg]
Cummins Incal to Cal converter - $25
Software for converting any Incal Calibration to Calterm format. Good for practicing using Calterm.
Cummins Incal CE 2.10.331 - $105
Main functions:
Change/Convert:
- Converting INCAL between different INSITE formats (from 7.5 to 8.7)
- Changing the expiration date of INCAL
- Password removal from INCAL files.
Other:
- Unpacking from INCAL to cal
- Packaging from cal to INCAL
- Injection of cal file into INCAL set
- Correcting checksum of cal files
- Adding a fake digital signature to cal and INCAL files.
Cummins InCal iMod Manager - $45
Utility to modify calibration files for outdated INCAL! You can change the expiration date for every calibration file. iNCAL M0d will notify if there's a problem with your files, or the wrong password to edit. iNCAL M0d is Full compatible with Insite 8 INCAL Files.
[Image: Cummins-InCal-iMod-Manager-2.jpg]
[Image: Cummins-InCal-iMod-Manager.jpg]
Cummins Incal unpacker, repacker, date changer - $79
UnPack Incal files, WorkOrders files. RePack Incal. Change Incal date.
[Image: Cummins-Incal-unpacker.jpg]
Cummins Full Manuals All Models - $165
Cummins InPower Pro 14 (with keygen) - $1070
Cummins Inpower Pro 14 - $165
Cummins Inpower Pro 11.5 - $55
InPower provides the following functions for monitored equipment:
  • Direct connection capability from a personal computer to PowerCommand genset controls, transfer controls, and system controls; For details on devices supported refer Technical Details tab.
  • Connection to generator set or transfer switch controls via modem or to multiple controls.
  • Allows the monitored equipment to send alarm information to a connected computer.
  • Configurable for units of measurement, and level of user access (read-only, read/change values, administrator).
  • Adjustment of nearly every adjustment parameter within the connected control system, including parameters such as voltage and frequency levels, gains, protection set-points, other values.
  • others.
[Image: Cummins-Inpower-Pro.jpg]
Cummins InCal Tool 8.5 - $299
Cummins Incal Tool 7.0 (with keygen) - $2490
Cummins Incal Tool 7.0 - $175
Cummins Incal Tool 6.0 - $155
[Image: Cummins-INCAL-Tool-6.0.jpg]
Fix v3 for Cummins Incal - $85
Cummins PowerSpec 9.1 - $315Cummins PowerSpec 8 - $299Cummins PowerSpec 6.1.1 2016 - $199
Cummins PowerSpec is an electronic tool that makes it possible to tailor the operation of Cummins engines in every on-highway engine application.
PowerSpec full functionality is available to support all Cummins 2013 On-Highway engine products (ISX15, ISX12, ISL9, and ISB6.7), 2010 engine products (ISX15, ISX12, ISL9, ISC8.3, and ISB6.7), 2007 products (ISX, ISM, ISL, ISC, ISB), some of the Natural Gas products (ISL G and ISX12 G) and earlier products. Features include a gearing calculator, complete descriptions of electronic features, instructions on how to optimize parameter settings, and access to trip information and fault code data. It also supports fault codes and trip information on Euro 3/4.5/5, ISBe, N14+, M11+ CELECT Plus engines. Another functionality is not available for the Euro 3/4.5/5, ISBe, Celect Plus engines.
[Image: Cummins_PowerSpec.jpg]
Cummins Wiring Diagram - $99Cummins Comercial Marine Diesel Engine Wiring Diagram - $99
Video course Cummins QuickServe Online for beginners - $55
How to create a FREE Cummins QuickServe Online account
What the difference between a free and a paid account is
Analysis of the different sections and the information they contain
How to read Cummins wiring diagrams for your selected engine
How to use the Operation and Maintenance manual
Cummins Technician Training - $135
What inside
Cummins Heavy Duty Engines + Midrange Trainings - $199
What inside
Cummins CM2250 DPF NOX Delete + Video - $99[/size]
Added a new version - Cummins Insite 8.7 Pro
Added a new version - Cummins Inpower Pro 13
Thanks given by: vigfab
Added Cummins Insite 8.7 Pro with keygen
Added a new program - Cummins INCAL Tool 6.0
Added Cummins Calterm 5.3
Added Cummins Calterm 5.3.3
Added Cummins Full Manuals All Models, PowerSpec 6.0 2015, 6.2 2016
Added Fix for Cummins insite 8.7.086 Zapit for unlock ECM
12 Guest(s)
