| #1 |
AGCO - Good truck diagnostics device with European Union quality
Dealer scanner AGCO 2x4 CAN USB Interface for the diagnosis of agricultural machinery and special equipment AGCO.
Connecting to the machines takes place using the CAN bus. The scanner allows you to make a complete diagnosis right in the field, which makes it possible to quickly identify a malfunction. The device has the ability to read ECU errors and erase them from memory.
In addition to troubleshooting, the diagnostic scanner allows you to program control units, as well as change the factory settings. The device operates offline. The program has a convenient menu, supports more than ten interface languages, including English, German and Russian. The translation of the interface is technically competent.
The diagnostic scanner is made in a durable case, has compact dimensions and a reliable connector for connecting.
Supported Brands:
![[Image: AGCO.jpg]](http://motorstate.com.ua/upload/forum/AGCO.jpg)
![[Image: AGCO-2.jpg]](http://motorstate.com.ua/upload/forum/AGCO-2.jpg)
![[Image: AGCO-3.jpg]](http://motorstate.com.ua/upload/forum/AGCO-3.jpg)
![[Image: AGCO-4.jpg]](http://motorstate.com.ua/upload/forum/AGCO-4.jpg)
Need it? Write to me to discuss the details.
Supported Brands:
- AGCO
- Challenger
- FENDT
- FELLA
- GLEANER
- Laverda
- Massey Ferguson
- RoGator
- ISEKI
- SISU
- SpraCoupe
- Sunflower
- TerraGator
- Valtra
- WHITE Planters.
- AGCO Electronic Diagnostic Tool
- AGCO SISU Power WinEEM3 Service Tool (WinTest)
- AGCO SISU Power WinEEM4 Service Tool
- FENDT FenDias.
- AGCO adapter 2x4 CAN USB
- 2 x 9-pin Deutsch cable
- 12-pin cable for Fendt (Deutz engines)
- Cable 16-pin for Massey Ferguson & Valtra
- 4-pin cable for Fendt.
