Latest news: ---- Subaru SSM3 Universal J2534 04.04 Patch Full ---- SCANIA SDP3 TRUCKS + MARINE + KEYGEN ---- CUMMINS INSITE 9.3.1-10.0-10.1 PATCH FIX TOOL ---- Iveco Power Trucks Buses 2020 Full MEGA ---- Lsuite 1.2 Checksum Tool Full ---- Ksuite For Ktag 7.020 ---- Lsuite 1.03 v2 Checksum Tool Full ---- PCMFlash ECU Master KTM 1.20 ---- DTS Monaco 9.04.16 Activation TOOL ---- NYO 4.0 (2017) Full + Pictures Tested Working ---- Hello from Germany ---- Renault VCI3 (V240) Complete + Activator ---- Dialogys 4.78 Renault Dacia Workshop Manuals Electronic Parts Catalog ---- Vehicle Fleet Manager + Keygen Full ---- CAT Factory Password Generator Tool Collection FULL ---- WOW 5.00.12 + KEYGEN FULL ---- Vediamo Fullfix + Passthru Support OpenPort ---- AirbagCrashKiller 7.8.4 + KG ---- Auto Correct TPROT PCMtuner EDC17C60 PSA ---- DTS 9.04.0016 License TOOL ---- Elite Convert Winols KP Files Tool ---- WEBASTO DIAGNOSTIC WTT V3.8 NEW UPDATE ---- PCMflash Dongle Emulator V0.1.2 For Versions 1.2.0 And 1.2.1 ---- BMW Standard Tools 2.12 FULL ---- BMW CIC Patcher v2 Generate Your Retrofit FSC Certificates ---- MB SeedKey Generator Complete Software ---- BMW ISTA 4.62.2x VERSION I-LEVEL OVERVIEW ---- TOYOTA LEXUS TUNER V2 FULL ---- PCMflash 1.2.0 - 1.2.1 Dongle Security TOOL ---- DTSProjects for DTS 9.04.016 ----
Carly Pro 49.40 Full Unlocked All Car Brands (phone diagnostics)
I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.
Added a new version Carly Pro 46.18 All Car Brands
Thanks given by: Admin
Added a new version - Carly Pro 46.22 Full.
What's new:
- New codings for Audi, VW and BMW models 2007 - 2014
- New function for newer BMW models (starting roughly 2013): Engine Adaptation Reset
- Bugfixes for frozen Health checks
- Bugfixes for frozen application dashboard.
Thanks given by: Gh0sted10
Added a new version Carly All Car Brands 46.27.
Added a new version - Carly Pro 46.44 All Car Brands.
What's new:
Improved fault texts for newer VW, Audi, Seat & Skoda models (starting roughly 2014)
Coding for BMW G-models vastly improved: Video in motion, engine start stop memory added and much much more
Added a new version - Carly Pro 47.51 beta
Added a new version - Carly Pro 46.58
Added a new version - Carly Pro 46.63 + 50.04 beta
Added new version - Carly Pro 46.64. Whats new:
- All Carly brands in ONE app
- Fault information for BMW models between 2005 and 2020 improved with additional repair tips (only available for selective faults)
- Ford diagnostics now available as professional workshop level diagnostics! Carly will now show you the same error codes (incl. fault descriptions) as in a Ford workshop
- Improved fault texts and new parameter function for all supported Mercedes models
Added new version - Carly Pro 46.65
9 Guest(s)
