Latest news: ---- Volvo Tech Tool Devtool License Editor Keygen Full ---- Fiat ecu map ---- SVEdit v1.1.38 ---- BMW E-SYS PSdZData Tool New Version Link MEGA ---- VEDIAMO PASSTHRU 5.1.1 + KG + PATCH ---- GM ECU FLASHER TOOL FIX ---- BMW CODING PACK FILES MEGA ---- iDecoder 4.5 No HWID Full ---- ECU Tuning Solutions 1.02 No HWID ---- VCDS HEX NET SUPPORT WIFI DOIP TOOL ---- BMW ETK Price 11.2026 ---- K-Suite Collection Professional Software Kess V2 K-TAG ---- GM GDS2 SOFTWARE + KEYGEN + PATCH ---- ECU Repair Guide Electronic Tool 2022 ---- BMW E-Sys 26.04.02 New Version MEGA ---- Best K-Suite Version For Kess 5.017 K-Tag 7.020 ---- Immo Doctor 2.1 + Multi Editor + DTC Off + Keygen ---- Subaru SSM3 Universal J2534 04.04 Patch Full ---- SCANIA SDP3 TRUCKS + MARINE + KEYGEN ---- CUMMINS INSITE 9.3.1-10.0-10.1 PATCH FIX TOOL ---- Iveco Power Trucks Buses 2020 Full MEGA ---- Lsuite 1.2 Checksum Tool Full ---- Ksuite For Ktag 7.020 ---- Lsuite 1.03 v2 Checksum Tool Full ---- PCMFlash ECU Master KTM 1.20 ---- DTS Monaco 9.04.16 Activation TOOL ---- NYO 4.0 (2017) Full + Pictures Tested Working ---- Hello from Germany ---- Renault VCI3 (V240) Complete + Activator ---- Dialogys 4.78 Renault Dacia Workshop Manuals Electronic Parts Catalog ----
JPRO 2021 NO KEY
alexhong1 Offline
some one have key make ?
Thanks given by: Prodrive , Dejalue , jimford
Please Read Carefully The Rule
08: DO NOT post Links on the Board. Links must be attached in a text file.
https://automotiveforum.net/showthread.php?tid=8011
DUPA Offline
I have yet to see a crack for JPRO 2019 / 2020 / 2021 done properly. First off, you will need a loader that updates the date in the lic.dat file each time program is loaded. Second, you will need to patch/update/replace the databases, not only volvo/mack but also the main one the program uses to check compatibility of bidirectional. Otherwise you will be missing many of the options that normal JPRO 2019/2020/2021 has under bidirectional tests. There is even more to doing this properly such as patching out the other license checks or blocking in internal firewall.
alexhong1 Offline
(06-30-2021, 03:16 AM)DUPA Wrote: I have yet to see a crack for JPRO 2019 / 2020 / 2021 done properly. First off, you will need a loader that updates the date in the lic.dat file each time program is loaded. Second, you will need to patch/update/replace the databases, not only volvo/mack but also the main one the program uses to check compatibility of bidirectional. Otherwise you will be missing many of the options that normal JPRO 2019/2020/2021 has under bidirectional tests. There is even more to doing this properly such as patching out the other license checks or blocking in internal firewall.
Yes for now Jpro 2021 need active when  you open the program
