Latest news: ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ---- Can Clip 221 Passthru Keygen + Patch Full ---- FoxFlash Offline Loader ECU TCU Programming Software ---- PCR2.1 Immo Remover 2.4 Tool VAG FULL ---- DDT4 ALL 5.5.07 FILES MEGA ---- Volvo Tech Tool PTT 1.12 + Keygen Full ---- xDecoder 14.0 Launcher Package Fix ---- HP Tuners 5.1.1.198 + VCM Keygen FULL ---- SM3 Scanmatik Alpha4 PCMflash ---- JLR SDD ENGINEERING CALCULATOR TOOL ---- Zenzefi Root And Backend Certificates ---- FoxFlash Offline ECU Tuning Files Full ---- BMW CAS4 CAS4+ Editor v1.2 FULL ---- GPEC2 GPEC3 UNLOCKER TOOL FULL ---- Zenzefi Aftersales Certificate 23.11.2026 Full ---- Diagbox 7.57 Files Complete Full ---- Man Mantis 12.2025 Full Activated ---- Mercedes WIS ASRA Standalone 10.2021 Activated ---- DTS 9.02 Keygen Patch FULL ---- DTS Monaco 8.16.015 Keygen Patch FULL ---- FoxFlash Offline Loader For KTM 200 Complete ---- DTS Monaco Projects Files Collection FULL ---- Smart 453 0.9 Turbo 66kw - need stage1 file ME17 9.20 ---- WinOLS 4.7 Native Installer + Complete Guide ---- Iveco Easy 18.1 Trucks + Buses + Keygen + Instruction ----
Carly Pro 49.40 Full Unlocked All Car Brands (phone diagnostics)
I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.
Added a new version Carly Pro 46.18 All Car Brands
Thanks given by: Admin
Added a new version - Carly Pro 46.22 Full.
What's new:
- New codings for Audi, VW and BMW models 2007 - 2014
- New function for newer BMW models (starting roughly 2013): Engine Adaptation Reset
- Bugfixes for frozen Health checks
- Bugfixes for frozen application dashboard.
Thanks given by: Gh0sted10
Added a new version Carly All Car Brands 46.27.
Added a new version - Carly Pro 46.44 All Car Brands.
What's new:
Improved fault texts for newer VW, Audi, Seat & Skoda models (starting roughly 2014)
Coding for BMW G-models vastly improved: Video in motion, engine start stop memory added and much much more
Added a new version - Carly Pro 47.51 beta
Added a new version - Carly Pro 46.58
Added a new version - Carly Pro 46.63 + 50.04 beta
Added new version - Carly Pro 46.64. Whats new:
- All Carly brands in ONE app
- Fault information for BMW models between 2005 and 2020 improved with additional repair tips (only available for selective faults)
- Ford diagnostics now available as professional workshop level diagnostics! Carly will now show you the same error codes (incl. fault descriptions) as in a Ford workshop
- Improved fault texts and new parameter function for all supported Mercedes models
Added new version - Carly Pro 46.65
