Latest news: ---- DELPHI 2021.10B + AUTOCOM 2021.11 FILES MEGA ---- DPDU Passthru Driver TOOL ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 FULL ---- TOYOTA DENSO ECU IMMO DTC FILES MEGA ---- Xentry SDconnect Toolkit Fix 09.2026 ---- XENTRY RELEASE 4 - 09.2026 FILES ---- SRS AIRBAG CRASH KILLER + KEYGEN FULL ---- Kraken Auto Database ECU Tool ---- Autotuner File Converter Tool ---- SDT-II 2.43.0.126 Files MEGA ---- MUT-III PassThru 26061-00 Files MEGA ---- BMW ISTA GUI 2.1.0 NEW UPDATE ---- Scania DEC2 Engines Control System Software Files ---- BMW ISTA 4.57.21 Polish Language ---- BMW PSdZData 4.61.30 Files FULL ---- FVDI Software Download Files MEGA ---- FTAG 1.1.0 Checksum Correction Tool MEGA ---- All BMW Maps In One Place Files Torrent ---- BMW Easy Connect 2 1.4 TOOL ---- FTAG 1.0.1 Checksum Tool + Keygen FULL ---- VAG Dash Editor Tool FULL ---- JLR SDD 167 VM FILES MEGA ---- HU45 JP ECE FILES MEGA ---- ECU Forge - Converter KP to XDF ---- Error p0012 on Peugeot 206 1.4 16v (kfu) ---- ebs 3 wabco checksum correction ---- ODIS 26 + Patch ---- Unlock ECU Seed key Calculator TOOL ---- ZOOMLION ZCC550V MANUAL NEED HELP ---- XENTRY XDOS XPT 09.2026 FILES MEGA ----
Remote Install - Volvo Premium Tech Tool (PTT) + DevTool, Vodia, Impact, Prosis, VIDA
Volvo
Remote Install - Volvo Premium Tech Tool (PTT) + DevTool, VISFED, Vodia, EWD, Impact, Prosis, VIDA, Matris
Volvo Premium Tech Tool PTT 2.8.221 + APCI 2023 + DevTool (with keygen) - $650
Volvo Premium Tech Tool PTT 2.8.301 + APCI 12.2024 + DevTool - $275
Volvo Premium Tech Tool PTT 2.8.250 + APCI 2024 + DevTool - $175
Volvo Premium Tech Tool PTT 2.8.130 + APCI 2022 + DevTool (with keygen) - $490
Volvo Premium Tech Tool PTT 2.8.130 + APCI 2022 + DevTool - $175
Volvo Premium Tech Tool PTT 2.8 + APCI 2022 + DevTool (VMware) - $99
Volvo Premium Tech Tool (PTT) 2.7.25 + DevTool + APCI 2021 - $115
Volvo Premium Tech Tool PTT 2.7.116 + APCI 06.2022 + DevTool - $165
Volvo PTT just update APCI bases - $29
Volvo Premium Tech Tool software is designed to diagnose and program Volvo trucks and buses, Volvo Construction Equipment, Volvo Penta, Mack Trucks, Renault Trucks, UD Trucks. The software is installed on a PC running Windows 10 x64, and exchanges data streams with the vehicle ECU via diagnostic scanners Vocom 88890300, Vocom 88894000, Nexiq, or PassThru.
Features of this software version:
  • Added support for new models FH4 and FM4
  • Work with cars Euro 6
  • Volvo bus service
  • Work with Volvo construction equipment. Volvo Penta
  • Mack Trucks support
  • Renault Trucks car service
  • Maintained support for the old electrical system.
Functional features of the Volvo Premium Tech Tool:
  • Intermediate data storage is provided, and accordingly OffLine programming;
  • It is possible to install the Developer Tool software to open the advanced mode.
Applicability of Volvo Premium Tech Tool software:
  • Diagnostics of trucks, buses, special equipment Volvo
  • Programming of all electronic control units
  • Adjustment of speed limiters (odometers)
  • Calibration of parameters, such systems as pneumatic suspension, electronic control units and other vehicle systems
  • Support for all brands and models supported by Tech Tool (VCADs Pro).
[*][Image: Volvo-Premium-Tech-Tool-PTT-2-8-140.jpg]
Volvo PTT Parameter Description - $179
[Image: Tech-Tool-PTT-Parameter-Description-V2-M...UNLOCK.jpg]
Volvo Truck + MACK Delete Flash Files 2018 (with 2021 updated) - $330
What inside - 12 Gb files for:
  • Volvo + MACK delete Flash Files
  • Amarilla Volvo IS files
  • Mack USA delete
  • Original Volvo flash files
  • Volvo delete files
  • Volvo USA delete
  • Volvo V3 delete
Volvo P3tool 1.0.1.9 for j2534 VCI (it has 50 tokens) - $95
It lets read/write the CarConfig on Volvo P3 cars - S80 2007-2016, V70 2008-2016, XC70 2008-2016, XC60 2010-2016, S60 2011-2018, V60 2014-2018,V40 2012-2019.
Tokens for Volvo P3tool - 50 credits for 5 cars, total 250 credits - $345Tokens for Volvo P3tool - 50 credits for 1 car, total 50 credits - $75
[Image: Volvo-P3-Tool.jpg]
Volvo Penta Vodia 5.2.96 + APCI 2023 - $549Volvo Penta Vodia 5.2.50 + APCI 2022 (unlocked) - $495Volvo Penta Vodia 5.2.50 + APCI 2018 - $370
The main functions:
  • Event log, motor parameters (Log test)
  • Reading error codes
  • Checking software versions, programming
  • ECU Information
  • Cylinder acceleration test
  • Cylinder Compression Test
  • The manual shutdown of injectors
  • Motor load test
  • Recall campaigns (software replacement)
  • ECU programming
  • ACP (Active Corrosion Protection) chassis test
  • Checking the conformity of all control units
  • Calibrating transom and IPS speakers
  • Reading engine hours.
[Image: Volvo-vodia.jpg]
Volvo XC60 Electrical Wiring Diagrams 2022 - $75
For models: Volvo XC60 B6 AWD L4-2.0L Turbo VIN 06 B420T SC MHEV
Volvo EWD Electrical Wiring Diagrams Trucks & Buses - $149
Volvo EWD 12.2017 Electrical Wiring Documentation - $99
Volvo EWD 2014 Electrical Wiring Documentation - $45
Wiring diagrams for all Volvo cars that left the assembly line from 2004 to 2013. The disc contains detailed information on the location, various connectors, sensors, devices, control units, fuses, relays, and equipment, as well as wiring diagrams and colors of wires. In the program, you will find information about fuses and relays and a description of the purpose for each of them. The Volvo EWD 2014D catalog contains information for the following Volvo models: C30, S40, V40, V40 Cross Country, V50, S60, V60, XC60, C70, V70, XC70, S80, S80L, XC90.
All information is presented in the form of full-color illustrations, with a description in English, Swedish and Finnish. For the convenience of searching for information, all the information is divided into sections in which you can find the necessary electrical circuits for a particular car model and year of manufacture. The information presented on the disc is the most complete and accurate, but for later and early model years of the presented cars may not be suitable, as the company may make changes in the design and equipment.
Volvo Impact 2022 - $299
Volvo Impact 2022 online (via remote desktop) 12 months - $135
Volvo Impact 2022 online (via remote desktop) 3 months - $59
Volvo Impact 2022 online (via remote desktop) 1 month - $35
Volvo Impact EPC 2020 - $175Volvo Impact EPC 2019 - $99Volvo Impact EPC 2018 - $559
This catalog contains only Volvo trucks and buses of the European market. The Volvo Impact dealer and bus dealer and bus dealer base includes Volvo truck spare parts catalog, repair, maintenance, diagnostics, specification manuals, service bulletins, standard hours, decryption of diagnostic trouble codes and tools for Volvo trucks and buses.
Volvo Prosis 12.2024 - $375
Volvo Prosis 03.2024 - $350Volvo Prosis 08.2022 (with keygen) - $1350Volvo Prosis 12.2023 - $285Volvo Prosis 08.2019 - $99Volvo Prosis 2019 online (via remote desktop) 12 months - $135Volvo Prosis 2019 online (via remote desktop) 3 months - $59Volvo Prosis 2019 online (via remote desktop) 1 month - $35
Spare parts catalog and repair manual on Volvo construction equipment (loaders, excavators, graders, asphalt pavers). It contains a catalog of spare parts, instructions for repair and maintenance, electrical diagrams, hydraulic circuits for all models of Volvo construction and agricultural equipment.
[Image: Volvo-Prosis.jpg]
Volvo VIDA 2022 (1 time online access) - $99Volvo Vida Dice 2014D - $75
The official application for diagnostics, search for spare parts, contains step-by-step instructions for repairing Volvo cars.
[Image: Volvo-Vida.jpg]
Volvo Penta EPC 03.2025 - $135
Volvo Penta EPC 12.2021 (VMware) - $55
The program Volvo Penta EPC is a directory containing a detailed list of spare parts and accessories, parts book, parts manuals, spare parts management, technical specifications, special instructions, designed to serve the propulsion and power systems for marine and industrial applications.
[Image: 352cf8081883530788cb4f1361df1fb4.jpg]
The program is an encryptor/decryptor for ECU firmware files, which, in addition to encoding/decoding, also carries out their editing.
Volvo Encryptor / Decryptor allows the user to access ECU programming Volvo trucks (ECU MID 128, 144, 130, etc.) You need to download a file TMP with the required computer number (you can see the computer number using Volvo diagnostics PTT) into the working window of this utility and enter your Dealer ID and client ID.
Volvo Encryptor-Decryptor allows you to program the computer for any specified dealer and client ID and can convert TMP files to XML format and back. The kit also includes programming files.
Volvo VISFED 3.4 + Cars ECU files - $179
Include files for Volvo cars Volvo 240, 850, 940, 960, FH12, S40, S60, C70, S70, S80, V40, V70, XC90
Volvo VISFED 3.4 + Base of files to remove SCR and increase HP for Volvo, Renault - $645
Volvo IS File ED (VISFED) - is special software to decrypt, edit, encrypt ECU reload (also called intermediate storage) files for Volvo, Renault, Mack trucks. The tool is made to make all file rebuilding processes as simple and easy as possible. It also allows viewing ECU file and other information of part and subpart numbers, parameters, PID, PPID, SID, PSID, FMI. Checksum calculation possible of Intel HEX line and whole CSW file.
Supported:
  • Adding language
  • Reload ECU with the original software
  • Remove SCR + increase horsepower on: Volvo trucks (D9B, D11C, D13A, D13B,D13C, D16C, D16E engines)
  • Remove SCR + increase horsepower on: Renault trucks (D11A, D11B, D11C, DXi13A engines)
[Image: Volvo-visfied.jpg]
Volvo Matris 2.4 2020 (with keygen) - $1850
Volvo Matris 2.4 2020 - $185
Volvo Matris 2014 - $65
MATRIS is an abbreviation for the English Machine Tracking and Information System, which translates as a machine and information tracking system.
Volvo MATRIS is a special analytical system that connects to the electronic systems of Volvo construction equipment, allowing you to analyze the history of the machine.
[Image: Volvo-Matris.jpg]
Volvo Visfed Flash Editor Revolation Tea2 (only Covertion Xm/Tmp) - $490
Volvo Visfed Flash Files - Volvo Truck (23000 pcs) - $1800
Volvo Visfed Flash Files - Renault Truck (2766 pcs) - $1250
Volvo Visfed Flash Files - Mack Truck (1219 pcs) - $1150
Volvo Visfed Flash Files - UD Truck (132 pcs) - $850
Volvo Visfed Flash Files - Volvo Construction Equipment (17165 pcs) - $1800
Volvo Visfed Flash Files - Penta (132 pcs) - $650
Visfed Flash Editor Revelation Tea2 is a special Software for Volvo OBD pre-2013 (Tea2, APCI) that includes Flash Programs, Parameter modification and more.
Mode with PTT
Connect to your vehicle with Techtool. Then find and Program the files specific to your vehicle with the Flash editor Tea2.
  • It receives Vehicle Information via Techtool
  • Flash Programming via Techtool
  • Support Volvo, Renault, MACK, UD, Penta, BUS, Volvo Construction
Mode without PTT
It's directly connected to your vehicle. Techtool is no needed.
  • Parameter programming access
  • Clean fault codes
  • ECU flash programing
Binary Editor Tool
With programs such as Kess, Ktag, Galletto, MagPro you can convert the ECU Binary Files you read into a Writable Format with Flash Editor Tea2 with Techtool.
[Image: Visfed-Flash-Editor-Revolation.jpg]
Volvo Truck FL6 Service Repair Manual - $155Volvo Truck Fh-16 2015 Workshop Service Repair Manual - $89Volvo Ec700b Lc Ec700blc Excavator Service Repair Manual - $89Volvo Mc110c Mc115c Mc125c Mc135c Mc155c Mct110c Mct125c Mct135c Mct145c Skid Steer Loader Service Parts Catalogue Manual - $85Volvo L150E front loader Service Repair Manual - $85Volvo A40e Articulated Hauler Workshop Service Repair Manual - $89Volvo Penta TAD1241GE Generator Workshop Service Repair Manual - $89Volvo EC360B Prime Excavator Workshop Service Repair Manual - $89
Volvo Truck Wiring Diagrams Collection - $135
List of modeles:
B0E B11R B11R (3) B12B B12M B12R B13R B5LH B5LH (3) B5LHC (3) B5RH B5TL (3) B7FB B7R B8L (3) B8R (3) B8RLE (3) B9L B9LA B9R B9S B9TL BXRC DE FE FE (3) FH FH (4) FH12 FH16 FH565 FL FL (3) FL10 FL12 FL6 FL7 FLC FM FM (4) FM10 FM12 FM7 FM9 FS7 NH12 NH565 VM
Need it? Write to me to discuss the details.
Added - Visfed 0.3.2
Added new versions - Volvo PTT 2.8.26 and APCI bases 12.2020
Added a new program - Volvo Vodia
Added Volvo Matris 2.4 2020 (with keygen) and Volvo PTT Just update APCI bases
Added a new version - Volvo Penta EPC 2021
Added a new version - Volvo Penta Vodia 5.2.50 2020 (unlocked)
Thanks given by: GORSKI1
Added a new version - Volvo Techtool 2.8.51 Full + Development tool 03.2021
Added - Volvo Truck + MACK Delete Flash Files
Added a new version and updated the price for Volvo PTT 2.8.6 Full + DevTool, APCI 05.2021
