Latest news: ---- John Deere Advistore 5.4.44 ag+cf 2025/07 ---- SIM3K543-E2 ECU Catalyst Off Calibration TOOL ---- PORSCHE Piwis IV 44.200.001 + 38.250 Engineering PET2 PCM FULL ---- XENTRY XUS DAS WIS EPC STARFINDER VEDIAMO MONACO 09.2026 ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ----
Carly Pro 49.40 Full Unlocked All Car Brands (phone diagnostics)
I provide links to apk files that I do not test myself, these should be full versions, but sometimes this is not the case.
Added a new version Carly Pro 46.18 All Car Brands
Thanks given by: Admin
Added a new version - Carly Pro 46.22 Full.
What's new:
- New codings for Audi, VW and BMW models 2007 - 2014
- New function for newer BMW models (starting roughly 2013): Engine Adaptation Reset
- Bugfixes for frozen Health checks
- Bugfixes for frozen application dashboard.
Thanks given by: Gh0sted10
Added a new version Carly All Car Brands 46.27.
Added a new version - Carly Pro 46.44 All Car Brands.
What's new:
Improved fault texts for newer VW, Audi, Seat & Skoda models (starting roughly 2014)
Coding for BMW G-models vastly improved: Video in motion, engine start stop memory added and much much more
Added a new version - Carly Pro 47.51 beta
Added a new version - Carly Pro 46.58
Added a new version - Carly Pro 46.63 + 50.04 beta
Added new version - Carly Pro 46.64. Whats new:
- All Carly brands in ONE app
- Fault information for BMW models between 2005 and 2020 improved with additional repair tips (only available for selective faults)
- Ford diagnostics now available as professional workshop level diagnostics! Carly will now show you the same error codes (incl. fault descriptions) as in a Ford workshop
- Improved fault texts and new parameter function for all supported Mercedes models
Added new version - Carly Pro 46.65
UPSMAN84, 6 Guest(s)
