Latest news: ---- XPROG 5.5.5 NO DONGLE NEED FULL ---- SCANIA SDP3 V2.70.1.3 FULL TRUCKS + MARINE + KEYGEN ---- BMW ISTA Updater GUI 2.0.0 TOOL ---- Bendix VCP ---- BMW Easy Connect ECC ISTA TOOL ---- VCM EDITOR COLLECTION FULL ---- VCDS Release 26.3.0 VIIPlus Loader 08.026.08 FULL ---- Winols 4.7 With Installer Full Mega ---- BMW CAS4+ EDITOR TOOL FULL ---- BMW ISTA 4.61.1x VERSION AND I-LEVEL OVERVIEW ---- ProSeCco Data Time Tool Full ---- CDA 6-J2534 bridge (Dubb45 Tool to use CDA with Passthru) ---- Subaru SSM4 Universal J2534 + Patch Full ---- Xentry Full Fix 4.9.8 Soft Easiest Installation Activation ---- Diagbox 7.57 Pack Complete Full ---- ODIS-S 26.0.1 + ODIS-E 22.0.0 + Fix Last Update ---- GM ECU FLASHER TOOL FULL ---- Hino DX3 v1.25.1 Diagnostic Solution Files Mega ---- Winols EDC15 Mappack Generator TOOL ---- xDecoder + Keygen 100% Work ---- VAG PCR 2.1 DECODER TOOL FULL ---- SDD use for LR Discovery 4 ---- Toyota Lexus GTS+ 2026 Offline Diagnostic Software ---- ECU Tuning Solutions + Keygen IMMO DTC EGR DPF ADblue OFF ---- BMW PSdZData 4.61.11 Torrent File FULL ---- BMW ISTA+ 4.60.30 Standalone Files FULL ---- GM GLOBAL B SEED KEY CALCULATOR ---- BMW ISTA Standalone 4.61.12 FULL MEGA ---- CAT SIS 01.2018 TORRENT FILE FULL ---- BMW ISTA GUI 1.4.6 TOOL FULL ----
Scania#4: repair COO7_A2C30127800_Basic
minimex Offline
Hi,
in the attachment is what you need for repair COO7, dumps: MPC and two eeprom. All files come from unlocked device.
K-Tag programmer (v. 6.070) for MPC5554 (plugin 246) and any for AT25256 ( ".bin" file also for MPC).
In the set a description of how to connect a K-Tag with a COO7 pcb.
Changing balls under MPC is a different procedure,
you need station for removing and assembly of BGA, stencil, balls,  good flux and also manual skills, and you have to remove the varnish!
Good luck.
Thanks given by: gerikogan , iglowarez , Minias22 , CVE123
gerikogan Offline
password, please
