Latest news: ---- Deutz-Fahr Tractors Factory Service Workshop Manuals ---- Ksuite 2.25 Clones Kess 5.017 Ktag 7.020 ---- ODIS Service 7.2.1 Multilang VAS5054A 6154 Passthru J2534 Win10 ---- HITACHI ALLINONE TOOL 3.9.0.0 MPDR 3.22 MEGA ---- VAG BMW MB OPEL PEUGEOT EDC17 FILES MEGA ---- Volvo Tech Tool Devtool License Editor Keygen Full ---- Fiat ecu map ---- SVEdit v1.1.38 ---- BMW E-SYS PSdZData Tool New Version Link MEGA ---- VEDIAMO PASSTHRU 5.1.1 + KG + PATCH ---- GM ECU FLASHER TOOL FIX ---- BMW CODING PACK FILES MEGA ---- iDecoder 4.5 No HWID Full ---- ECU Tuning Solutions 1.02 No HWID ---- VCDS HEX NET SUPPORT WIFI DOIP TOOL ---- BMW ETK Price 11.2026 ---- K-Suite Collection Professional Software Kess V2 K-TAG ---- GM GDS2 SOFTWARE + KEYGEN + PATCH ---- ECU Repair Guide Electronic Tool 2022 ---- BMW E-Sys 26.04.02 New Version MEGA ---- Best K-Suite Version For Kess 5.017 K-Tag 7.020 ---- Immo Doctor 2.1 + Multi Editor + DTC Off + Keygen ---- Subaru SSM3 Universal J2534 04.04 Patch Full ---- SCANIA SDP3 TRUCKS + MARINE + KEYGEN ---- CUMMINS INSITE 9.3.1-10.0-10.1 PATCH FIX TOOL ---- Iveco Power Trucks Buses 2020 Full MEGA ---- Lsuite 1.2 Checksum Tool Full ---- Ksuite For Ktag 7.020 ---- Lsuite 1.03 v2 Checksum Tool Full ---- PCMFlash ECU Master KTM 1.20 ----
FullFixBySamik v6.4.3 + Mercedes soft easiest installation activation
samo733792 Offline
New update FullFixBySamik v6.2
- Added program 7G SCN by Samik.
- Added key for WIS 07.2021 to 12.12.2025.
- Fixed a bug from v6.1 related to the offline login window in Xentry 2021.
- Also in Xentry 2021 there was no removal of ConfigAssist autorun, it was also added in this version.
- Added a "Close" button after successfully importing certificates.
- Added driver for Chinese Openport 2.0.
Thanks given by: X431 , X431
samo733792 Offline
New update FullFixBySamik v6.4.3
- The 7G SCN by Samik program has been updated.
- Fixed the SW Finder database.
- Updated Download Manager for downloading maps.
- Configured launch of WIS 07.2021 from Daimler Truck.
- Added a fix for SDConnect in Daimler Truck Platform Independent Diagnostics.
FullFixBySamik v6.4.1
- Fixed a bug from the previous version regarding the installation of ToolKit.
- Added a fix for opening WIS 07.2021 from Xentry.
- Updated DB in 7G SCN by Samik.
FullFixBySamik v6.4
- Added a fix for SDConnect to work with Xentry 03.2024.
- Fixed a small bug with DAS Sim when Xentry was NOT installed on the C drive.
FullFixBySamik v6.3
- XUS has been updated, now the database is from 02/05/2024 with 135,681 files (thanks to Linkov).
- Added a small fix for working with Xentry 03.2024.
- Fixed the problem with installing the VCX SE, VXDiag driver if Xentry is not installed on drive "C".
- Fixed problem installing VCX SE, VXDiag driver in Daimler Truck Diagnostics.
- Fixed a bug where the installation gave a syntax error if Xentry was not installed on the system.
- Functions related to WIS Standalone have been removed, since they were no longer relevant on new versions of Xentry. But WIS activation itself still occurs when Xentry is activated.
- Added a new certificate for diagnostics.
nano.113 Offline
can i set up a virgin key whit this fix? or there is a chance to scn components? i need to set up a new key because my mb doesnt have or someone that codes remotely?
