aleksey-
Nov 2019
Given 4848 thank(s) in 575 post(s)
aleksey-
Nov 2019
Updated price for ODIS 6, 7, 12
aleksey-
Nov 2019
Added VAG ODIS Service or Engineering - 12 months online updates
aleksey-
Nov 2019
Added
VAG iDEX neo 2.x.x. (installation, projects, 1 year license) and 1 or 5 year licenses
iDEX neo 2.2.3.0 updates:
General: Updated to iDEX essentials v176.5.2.
General: Fixed an error that occurred sporadically when exiting iDEX.
BUS trace: Fixed an error that occurred when tracing large amounts of data.
RPC+: Automated detection of required workarounds for certain interface versions.
RPC+: Polling timeout during SOD connection setup increased.
RPC+: The Reverse Socks Proxy is now waited for a specific time.
RPC+: Security mode query implemented.
RPC+: Optimization of assembly status query.
RPC+ TestClient: Disconnection to the VCI no longer triggers an exception.
Send Hex Module: Communication to control units is now terminated correctly.
Send Hex Module: Recording of the script functions now works correctly.
VCI selection: The PDU API used by ODIS is no longer added automatically.
VCI selection: In ""Other VCIs"" it is now possible to directly select a protocol type (CAN, CANFD, DOIP).
Actuator: Instead of the measured values, the selectable actuators are now directly displayed again.
Coding: If a control unit can no longer be reached after the reset, the module is now correctly discharged.
Encoding: Fixed an error that occurred when communicating directly with a DK2F in the encoding module.
P-Mode: Optimization of login/SFD queries.
Adaptation: Optimization of the process at KWP.
Basic setting: The results of the routine status are now also displayed.
Identification: Versions of the logical software blocks are now always read and transferred to the log.
aleksey-
Nov 2019
iDEX update – 2.3.1.5
Improvements 2.3.1.5:
General: Updated to iDEX essentials v179.0.9.
[iDEX-8265] Fixed error caused by nonexistent license.
[iDEX-8267] Fixed bug that did not install files correctly during setup.
[iDEX-8269] Fixed an error that could cause the application to crash.
[iDEX-8258] Error fixed when no certificate was found during SFD activation.
[iDEX-8148] No SFDe2e blocking is now carried out for application-based data records.
[iDEX-8244] Optimization of the control unit detection in the collection service.
[iDEX-8259] Improved recording of a hex service for the script.
Improvements 2.3.1.4:
General: Updated to iDEX essentials v179.0.0.
[IDEX-8229; IDEX-8186] General: Error correction in interaction with the CP tool for DoIP.
[IDEX-7960] General: Fixed an error that caused a freeze due to a VCI connection loss.
[IDEX-8190] Start page: Skipping the reading of the project information has been optimized.
aleksey-
Nov 2019
Added ODIS Service 9 installation.
aleksey-
Nov 2019
iDEX Update – 2.3.2.1
Improvements 2.3.2.1:
General: Updated to iDEX essentials v181.0.1.
[IDEX-8252] General: Improved stability.
[IDEX-8252] General: Improved handling of DoIP connection losses.
[IDEX-8332] Write data record: A correct session is now set for SFDe2e protected data records.
[IDEX-8332] Write data record: The ZDC name and version are now correctly set for SFDe2e protected data records.
[IDEX-8333] Collection service: The SFD structures are now also read out correctly in the collection service.
[IDEX-8352] AutomationApi: Fixed error in RpcFilesProgress.
Improvements 2.3.2.0:
General: Updated to iDEX essentials v179.3.0.
[IDEX-8280] General: Stability improvements.
[IDEX-7707] General: Improvement of the display in the identification window.
[IDEX-7764] General: The WLAN connection quality to the VCI is now displayed in the status bar and on the start page.
[IDEX-7543] General: Improved display of selected rows in different modules.
[IDEX-8098] General: Improved stability in connection with wrong or corrupted PDU-Api installations.
[IDEX-8302] General: Performance optimization of the detection of unreachable control units using DoIP.
[IDEX-8273] Installation list: Fixed an error that caused an incomplete installation list.
[IDEX-8272] Collection Service: fixed error caused by unanswered service from gateway.
[IDEX-8270] VPE signal: The signal is no longer activated when the project is loaded, but only when required.
[IDEX-8257] Session change: Changing the session could lead to an error with SFDe2e-capable control units.
[IDEX-8231] Write data record: OBD events are now only deleted for OBD control units.
[IDEX-8062] Write record: Temporarily created files are now correctly removed after execution.
[IDEX-8195] RPC+: File Transfer Server is now available again at the time of the LUM update.
[IDEX-8192] SFD: The tooltips of the different roles are now displayed correctly again.
[IDEX-8170] Script: Aborting the script caused a crash in some cases.
[IDEX-8154] Script: Fixed an error where the sub-participants were not read out in the MEB gateway.
[IDEX-8149] ServiceKey: The driver files of the reader are now copied correctly again.
[IDEX-8112] FoD/Swap: The extended session is now set for newer projects.
[IDEX-8090] Manage logs: fixed error when incorrect log path was specified manually.
[IDEX-8059] Measurements: Fixed an error that occurred due to the localization of a specific measurement.
[IDEX-7995] Diagnostic functions: Fixed an error that occurred due to a loss of connection to the ECU.
[IDEX-7978] Adjustment: Fixed error that occurred due to loss of connection to the ECU.
[IDEX-7967] AutomationApi: Implemented new functions to enable/disable the VPE signal.
[IDEX-7502] Production mode: The SFD role PRODUCTION is now used for the P-mode.
aleksey-
Nov 2019
iDEX Update – 2.4.0.4
Improvements 2.4.0.4:
General: Updated to iDEX essentials v182.4.10.
[IDEX-8397] General: Improved stability (in connection with the CP tool).
Improvements 2.4.0.3:
General: Updated to iDEX essentials v182.4.4.
[IDEX-8403] General: Workaround for the failure of the S-LW.
[IDEX-8377] Measurements: Measurements are now displayed correctly again.
Improvements 2.4.0.2:
General: Updated to iDEX essentials v182.4.3.
[IDEX-8400] Fixed bug where battery data was not read in collection service.
Improvements 2.4.0.1:
General: Updated to iDEX essentials v182.4.2.
[IDEX-8395] AutomationApi: Adaptation for the new overload of the 'Dataset.WriteData' method.
Improvements 2.4.0.0:
General: Updated to iDEX essentials v182.4.0.
[IDEX-8378] General: Improved stability (in connection with the CP tool).
[IDEX-8376] General: Fixed startup error caused by internal messaging.
[IDEX-8353] General: Improved performance when loading modules.
[IDEX-8306] General: Fixed error caused by internal messaging when exiting.
[IDEX-8157] General: Improved stability of internal messaging.
[IDEX-7917] General: The menu can no longer be collapsed.
[IDEX-8379] Send Hex Service: Improve stability when sending services.
[IDEX-6220] Send Hex Service: New functionality to select specific LogicalLinks for broadcasts.
[IDEX-8354] SFD: All SFD-capable control units are now displayed correctly.
[IDEX-8323] SFD: Fixed an error that was triggered by a controller that could no longer be reached.
[IDEX-7865] SFD: fixed error that occurred when connection was lost.
[IDEX-8291] SOD: The file type now only exists once in the POST.
[IDEX-8334] SOD test client: low level commands are now available.
[IDEX-8327] SOD: SecurityMode is now read out again after a reconnect.
[IDEX-8222] SOD: Functionalities for the interface 7/8 implemented.
[IDEX-8363] AutomationApi: new overload of 'General.ExecuteHexService()' to skip SFDe2e.
[IDEX-8334] AutomationApi: LowLevel commands are now available.
[IDEX-8261] AutomationApi: Objects for the SFD functionality extended to get information about error causes.
[IDEX-8230] AutomationApi: new overload of 'Dataset.WriteData()' to skip clearing OBD events.
[IDEX-8103] AutomationApi: New function 'Adaption.CheckCalibrationPreconditions()' implemented.
[IDEX-8331] Home page: Fixed an error that was triggered by internal messaging when loading a project.
[IDEX-8318] Home page: fixed an error that occurred when accessing a system-locked file.
[IDEX-8141] Start page: New function to unload the VCI and project.
[IDEX-8311] Script: New function to write an SFD reset token.
[IDEX-8274] Script: New functions to set the VPE signal.
[IDEX-8281] VCI Manager: Stability improvement with incompatible PDU APIs.
[IDEX-7905] VCI Manager: Fixed an error that occurred due to an incorrectly installed PDU API.
[IDEX-8275] SWaP: The correct result is now displayed in the event of an incorrect activation.
[IDEX-8052] Logs: fixed error triggered by sending to EasyVDS.
[IDEX-8002] Logs: Fixed an error that occurred after converting to ODIS format.
aleksey-
Nov 2019
iDEX Update – 2.4.1.4
Improvements 2.4.1.4:
General: Updated to iDEX essentials v185.1.7.
[IDEX-8488] SFD: Optimization for connection problems with the SFD backend.
Improvements 2.4.1.3:
General: Updated to iDEX essentials v185.1.6.
[IDEX-8465] Adjustment: The SFD unlock dialog for writing services is displayed correctly.
[IDEX-8466] Write data record: A reset is now carried out after SFDe2e-protected application data records.
[IDEX-8476] Collection service: The automatic log upload (collection service) is now only permitted for certain domains.
[IDEX-8477] Log upload: Improved detection of unknown or unauthorized AVx users.
[IDEX-8468] Flashing: When the VPE signal was activated, the communication to the HCP1 to be flashed was not established again.
Improvements 2.4.1.2:
General: Updated to iDEX essentials v185.1.4.
[IDEX-8199] General: Fixed an error caused by a problem in the internal release process that caused the application to crash.
Improvements 2.4.1.1:
[IDEX-8199] Logs: Revision of the log upload.
aleksey-
Nov 2019
iDEX Update – 2.4.1.5
Improvements 2.4.1.5:
General: Updated to iDEX essentials v185.1.8.
[IDEX-8503] VCI selection: With DoIP, the VIN and IP address are now displayed again.
[IDEX-8498] Identification: An ODX error resulted in an error message in 00A5 in the AU38X-PA.
