Latest news: ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ---- EDC16 EEPROM CHECKSUM TOOL ----
BMW 2026 ISTA ISPI NEXT, ISTA, ETK, INPA, E-Sys, Ediabas, KSD, Testo and WDS
Carsoftcar Online
BMW
BMW ISTA ISPI NEXT Licence Generator (You can use it to create licences for offline ISPI ISTA) - $350
BMW ISTA ISPI NEXT 4.49.40 (1 Tb) - $150
 BMW ISTA ISPI NEXT
Functions that will be available after installing the BMW ISTA D: automatic troubleshooting, reading / resetting errors, resetting service reminders, ECU adaptations, setting basic parameters, viewing measurement blocks, coding control units, information about control units, performer tests, programming units, other functions.
    List of programs included: BMW ISTA D, BMW ISTA-P, BMW Inpa, NCSEXPERT, WinKFP, Ediabus Conf, BMW ETK, NCS Dummy, BMW Coding Tool, Dr.Gini, ESYS Plus (additional option).
System requirements for BMW Ista:
• Laptop with at least i5/i7 processor
• RAM of at least 8 GB, but 16 GB and above is highly desirable.
• Availability of an SSD disk with a capacity of at least 1 TB, for Esis you need 2 TB
• Support Windows 10/11 x64 PRO
Some features of the ISTA system:
• It may not work completely with cars before 2014, it may not decipher fault codes or delete them, etc. This is due to the fact that the manufacturer removes support for old cars in new software versions. Therefore, for such cars we can install an older version.
• The system license is tied to the hardware and is protected from cloning. If deployed and run on another laptop, the license of the first one will be blocked. License restoration is equal to the cost of installation as for the first time.
Carsoftcar Online
BMW
BMW ISTA-D 4.5.12+P 3.72+E -Sys 3.8.1+PSdZDaten 4.50.12+INPA+Coding+NCS+EDIABAS+VIN KFP Tool+SP-Daten - $355 = $265
Carsoftcar Online
BMW
BMW ISTA+(D) Rheingold 4.57.30 - $75
BMW E-Sys Plus 4.54.20 Launcher Pro 1 yers - $350
Carsoftcar Online
BMW
BMW ISTA-D 4.57.30+E -Sys 4.54.20+PSdZDaten - $500 = $400
10 Guest(s)
