Latest news: ---- WinOLS File Unlocker Stage Extractor Tool ---- PROGRAM ECU TUNING SOLUTION 1.02 FREE FOR ALL ---- MAGIC TUNERS PACK + KEYGEN FULL ---- PROGRAM ECU TUNING SOLUTION 1.01 FREE FOR ALL ---- PETKA 8.9 FILES + VIN SEARCH FULL ---- MTX DTC REMOVER 1.8.5.0 + KEYGEN FULL ---- AlfaOBD PC Version PRO + Lic Generator ---- VCDS 26.9.0 LAST VERSION + LOADER FULL ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ----
Can CLIP v213 + Dialogys VM Full
joselitora Offline
(12-12-2022, 06:45 AM)Prodrive Wrote: Can CLIP v213 + Dialogys VM Full
Vmware preinstalled image with the following software:
Windows 10 Pro x64 clean image
CAN CLIP v213 (activated)
Dialogys 7.6.5
Renault Clip Tool (clip activation, radio pin code, etc.)
Clip Sonde Configuration (for older clip vci) + old drivers
Tested CANCLIP with Scanmatik 2 PRO
Hello,,  I need the pass,, pleaSE
REM6219 Offline
Dialogys 7.6.5
Hi, Would you please provide password?
pinotec Offline
hello
sure pass on attach is ok?
ipx200 Offline
Hey, thanks but the Pass is not right
Please send me the pass
mahiller Offline
Dialogys 7.6.5
can you pleaase send me part 5 and password
auto99 Offline
Hallo
 Part 5 missing
Please reup
Danke
stefantester Offline
File is not available, please reupload
New link has been updated
