Latest news: ---- MAN Cats II 12 - 14 + Activator FULL ---- CUMMINS INSITE 8.9 + CALTERM KEYGEN FULL ---- PETKA 8.3 - 10.2026 + VIN database 3.539.000 Full ---- TACHOSOFT MILEAGE CALCULATION SOFTWARE ---- MAN TG3 Q4.2021 MY23 WIRING DIAGRAM ---- R270 Programmer 1.20 Software FULL ---- WABCO TOOLBOX 14.9 FILES MEGA ---- TOYOTA + LEXUS TUNER SOFTWARE FULL ---- Current Database ECU Connection Diagrams ---- Airbag CrashKiller 7.8.4 + KG + Instruction ---- Mercedes Coding Programming Retrofix Tutorial ---- Multi PROG Script FILES ---- Ecu Data Sheet Helper Tool ---- Xentry Diagnostics Engineering Suite Full Fix ---- DAF Euro6 Service Repair Manual Pack ---- Freightliner Cascadia Gen5 Workshop Repair Manual ---- PTT 2.8.390 Tech Tool File MEGA ---- PTT 2.8.240 MFA Authorisation Plugin TOOL ---- MMI2G PATCH TOOL FULL ---- Top File Service Tuning ---- Wabco Diagnostic Software Full Package ---- Xentry Login Mode Switch Tool ---- DDT4ALL ECU FILES COLLECTION MEGA ---- BDM100 v1255 Galletto x64 + Installation Guide ---- Ksuite 2.25 Ktag 7.020 ECU Programming Full ---- Virtual Cockpit Plus Tool ---- Dashboard Service Tool 1.8 Mileage Correction Software ---- BMW PSdZData 4.62.12 Full Version ---- Case 621C 721C Loaders Service Manual PDF ---- Zenzefi Root And Backend Certificates 2027 ----
Ford IDS 130 + FJDS 130 + FDRS 43 + Mazda IDS 132 - for VCM2 / J2534
Added Ford FDRS 37.4.7
Added Ford IDS 130.01 + FJDS 130.01
annguyenvu Offline
(11-26-2020, 02:09 PM)aleksey-ms Wrote: Ford IDS 130.01 + FJDS 130.01 + FDRS 37.4.7 + Mazda IDS 129 - for VCM2 / J2534
IDS. IDS provides complete dealership level vehicle diagnostic coverage for all 1996 to select 2018 Ford, Lincoln, Mercury vehicles. IDS requires the use of Ford diagnostic hardware including VCM, VCM II, and VCMM devices. The IDS software license includes time-based access to the IDS software, software updates, calibration files.
FJDS provides module reprogramming software that covers 1996 to select 2018 Ford, Lincoln, and Mercury module reprogramming functions, plus complete dealership level diagnostic software for all 2018 to present Ford and Lincoln vehicles. FJDS is designed for use with J2534 compatible Vehicle Communications Interfaces (VCI) including Ford diagnostic hardware (VCM II, or VCMM). The FJDS software license includes time-based access to the FJDS software, software updates, and calibration files.
FDRS - next-generation factory Ford Motor Company vehicle diagnostic Software designed for use with VCM II, VCMM, and J2534 compatible VCI. FDRS provides complete dealership-level vehicle diagnostic coverage for some 2018 and forward vehicles. FDRS provides superior capabilities, is more user-friendly, and provides more diagnostic tools than IDS. The cloud-based system ensures the technician is provided the latest software every time FDRS logs into the Ford network.
[Image: Ford-IDS-.jpg][Image: Ford-FJDS.jpg][Image: Ford-RDRS.jpg]
PLEASE PASS SIR
PLEASE PASS SIR
Thanks given by: argegsm
Added Mazda IDS 131
fabiroz Offline
#136
(11-26-2020, 02:09 PM)Aleksey-MS Wrote: Ford IDS 130.01 + FJDS 130.01 + FDRS 38.5.7 + Mazda IDS 131 - para VCM2 / J2534
IDS. IDS proporciona una cobertura completa de diagnóstico de vehículos a nivel de concesionario para todos los vehículos Ford, Lincoln y Mercury de 1996 a 2018 seleccionados. IDS requiere el uso de hardware de diagnóstico de Ford, incluidos los dispositivos VCM, VCM II y VCMM. La licencia del software IDS incluye el acceso temporal al software IDS, las actualizaciones de software y los archivos de calibración.
FJDS proporciona software de reprogramación de módulos que cubre desde 1996 hasta determinadas funciones de reprogramación de módulos Ford, Lincoln y Mercury 2018, además de un software completo de diagnóstico a nivel de concesionario para todos los vehículos Ford y Lincoln 2018 hasta la actualidad. El FJDS está diseñado para su uso con interfaces de comunicaciones de vehículos (VCI) compatibles con J2534, incluido el hardware de diagnóstico de Ford (VCM II o VCMM). La licencia de software FJDS incluye acceso basado en el tiempo al software FJDS, actualizaciones de software y archivos de calibración.
FDRS: software de diagnóstico de vehículos de fábrica de última generación de Ford Motor Company diseñado para su uso con VCI compatibles con VCM II, VCMM y J2534. FDRS proporciona una cobertura completa de diagnóstico de vehículos a nivel de concesionario para algunos vehículos de 2018 y futuros. FDRS proporciona capacidades superiores, es más fácil de usar y proporciona más herramientas de diagnóstico que IDS. El sistema basado en la nube garantiza que el técnico reciba el software más reciente cada vez que FDRS inicie sesión en la red de Ford.
¿Lo necesitas? Pulsadores Tasa (Reputación) y Gracias, PM por el pase.
Added Ford IDS 130.02
Added Ford IDS 130.03
Thanks given by: Carls , Carls
arbenit Offline
(11-26-2020, 02:09 PM)aleksey-ms Wrote: Ford IDS 130.03 + FJDS 130.01 + FDRS 38.5.7 + Mazda IDS 131 - for VCM2 / J2534
6 Guest(s)
