#1 |
Multiecuscan is diagnostic software for hobbyists and the
workshop. In conjunction with the appropriate hardware, you can
carry out extensive diagnostics on your vehicle. Multiecuscan is
compatible for Alfa Romeo, Fiat, Lancia and Jeep.
- Software supports the following USB interfaces: OBDLink SX,
CANtieCar, ELM327 min.1.3a, OBD-Protect, OBD-Direct, OBDKey,
KKL K609, Stardiag Can327
- Software supports the following Bluetooth / Wlan interfaces:
OBDLink LX / MX, CANtieCar, OBDKey, Stardiag CAN327
- Access to many different control units in your vehicle.
- Reading and deleting fault memory.
- Display actual time data in tables and graphs.
- Perform actuator test.
- Make settings (proxy alignment).
- Reading of static data (ECU ID, system status, error codes).
- Perform service / oil reset.
- Saving and evaluating data.
- Software available in German, English and many other languages.
- Free updates for 1 year (after the updates have expired, your
software will continue to run indefinitely in the latest
version)
- The software is available in three different versions: PC
version, iOS, multiplexer version.
- License is valid for one computer (except multiplexer version).
- Software PC requirement: Min. 1.5GHZ with 1GB RAM. Operating
systems Windows XP, Windows Vista, Windows 7 (32/64), Windows
8, Windows 10 are supported. Net.Framework 3.5 must be
installed.
- These vehicles are currently supported by the software: Link
supported vehicles
INSTALL INFO
unpack, install & start the program once and close it
copy all files into the program dir and always start with our
loader
Attention: use Firewall
version)
installed.
supported vehicles
INSTALL INFO
loader
