CUMMINS v.8.70 KG - Printable Version +- Automotive Forum (https://automotiveforum.net) +-- Forum: (https://automotiveforum.net/forumdisplay.php?fid=1) +--- Forum: Trucks And Buses Software (https://automotiveforum.net/forumdisplay.php?fid=8) +--- Thread: CUMMINS v.8.70 KG (/showthread.php?tid=8608) |
CUMMINS v.8.70 KG - jimford - 12-29-2020 See if someone is successful activating this. Post back results. Test these out on a "dirty or test" machine. I have no idea if these KG's or infected. PM for Password. RE: CUMMINS v.8.70 KG - Trucknet - 12-30-2020 (12-29-2020, 05:25 PM)jimford Wrote: See if someone is successful activating this. Post back results. Tested and does not work RE: CUMMINS v.8.70 KG - jimford - 12-30-2020 It didn't work for me either. The patch opens and closes in a split second. I thought it was just me. RE: CUMMINS v.8.70 KG - Trucknet - 12-30-2020 (12-30-2020, 01:20 AM)jimford Wrote: It didn't work for me either. The patch opens and closes in a split second. I thought it was just me. Correct. I used on C drive, on desktop and inside the Cummins Folder but same happen. RE: CUMMINS v.8.70 KG - jimford - 12-30-2020 Let's see if someone make this work and post a better solution. |
