Firmware Database With Disabled EGR DPF FAP - Printable Version +- Automotive Forum (https://automotiveforum.net) +-- Forum: (https://automotiveforum.net/forumdisplay.php?fid=1) +--- Forum: Automotive Airbag Dash ECU IMMO (https://automotiveforum.net/forumdisplay.php?fid=13) +--- Thread: Firmware Database With Disabled EGR DPF FAP (/showthread.php?tid=4467) |
Firmware Database With Disabled EGR DPF FAP - Admin - 09-19-2019 In this topic, we collect firmware that has been modified to remove the particulate filter, EGR valve or made tuning. Only verified firmware that was not changed through volta or ecusafe programs. The presence of the original firmware is required RE: Firmware Database With Disabled EGR DPF FAP - Prodrive - 09-19-2019 Megane 3 sid 307 1.5dci dpf egr off Ford Transit 2014 2.2 SID208 SW: BK31-12A650-BB RE: Firmware Database With Disabled EGR DPF FAP - Prodrive - 09-19-2019 BMW 524D E34 2.4 D 1995 Tuned RE: Firmware Database With Disabled EGR DPF FAP - Prodrive - 09-27-2019 Ford F-250 DPF+EGR+Adblue Disable |
